0011 to 0006 Conversion Problem
Old May 20, 2009 | 03:09 PM
SEEnoEVO's Avatar
I have an 05 that I have tried converting over from 0011 to the 0006 and am having issues. I am now working with a very reputable tuner from this site, he started over fresh and it is doing the same thing. With the same settings, the 0011 map will idle and cruise 14-15, as soon as i put these settings into the 0006 rom, it idles and cruises at mid 13's. The tuner said he has never seen this before and has done MANY tephra mod switches. Any Ideas???
Old May 20, 2009 | 03:59 PM
SEEnoEVO's Avatar
Update*****
This is not actually true. The 0011 starts the idle at 14-15 but once the stft kicks in it drops it back down to mid 13's. The 0006 Never shows 14-15 it always stays low. Any advice?
Old May 21, 2009 | 08:09 AM
Fast_Freddie's Avatar
Veteran: Navy
Question... did you take the negative battery terminal off in between changes in ROMS to reset the fuel trims? Just a flash on the VIII won't reset the fuel trims like the IX. This may help the 006 ROM recalculate the IDLE stepper tables along with the fuel trims... Also are you adjusting the BISS after the switch to the 006 ROM?
Old May 21, 2009 | 08:14 AM
SEEnoEVO's Avatar
Yes and Yes. I am actually seeing about 14.3 average cruise and idle afr. I guess the tuner is also concerned about my scaling of 1170 for the 1050's. It does show my trims as +/- 2% but he is not comfortable. Feels something is wrong.
Old May 21, 2009 | 08:16 AM
Veteran: Navy
What is the STFT and LTFT (low) after 10-15 minutes of idle? And what is your STFT and LTFT (mid) & (low) after 20 minutes of cruise? And have you rescaled your MAF?
Old May 21, 2009 | 08:21 AM
SEEnoEVO's Avatar
All numbers are good Trims are within +/- 2% with the 1170. I have not scaled the MAF.
Old May 21, 2009 | 08:32 AM
Veteran: Navy
What are your injectors scaled to? Also you may want to convert your airflow to read in HZ and see what it is idling at (hz wise) this would be helpful to see if you need to scale your maf or not due to the intake tube...
Old May 21, 2009 | 08:40 AM
SEEnoEVO's Avatar
My 1050's are scaled to 1170 to get the trims in line. My airflow shows 38 at idle.
Old May 21, 2009 | 09:08 AM
MR Turco's Avatar
what RPM are you idling at?
Old May 21, 2009 | 09:19 AM
Veteran: Navy
Are the 1050's regular or Bluemax?
Old May 21, 2009 | 09:55 AM
SEEnoEVO's Avatar
I am idling around 1100 and they are supposed to be regular 1050's. The tuner is starting to think there is some mix up. The flow sheet I have shows 3 at 1072 and 1 at 1080 at 3 bar.
sabastian458
43
Nov 2, 2015 01:35 PM
Appauldd
Jul 28, 2009 06:43 AM
mick82907
Feb 2, 2009 08:32 AM
KBkilla0006
Mar 26, 2008 09:37 AM
evo9mr0006
Dec 26, 2007 07:08 PM
