Boost Leak Test - Help
Old Dec 27, 2008 | 01:04 AM
mick82907's Avatar
I have been researching the proper way to conduct the boost leak test for the past two days. The reason why I am conducting the test is a few days ago my Evo shut off while driving on boost from third to fourth. I did not miss any of the gears and did not over rev the engine. I was able to restart the car no problem but shortly after that I got the P0030 for a misfire code. I cleared the code out and then the car shut off again. This time followed by a P0011 which has to do with the intake cam angle sensor. That SES was followed by a different sound in the exhaust which sounded like a cross between an exhaust leak and my open wastegate but I was only at 1500 rpms. I also have a blinking/flickering oil light, but I have an oil pressure gauge which reads that I have the normal pressure. The car idles perfectly and shows no symptoms at idle.
After searching I have come up with the following:
Symptoms
Car Shut Off While Driving
P0030
P0011
Engine Noise Level
Flickering Oil Light
Tests
Fuse Check - All fuses are good
Oil Level - Good
Oil Condition - Good
Cam Angle Sensor Position Check - Perfect (Usually is installed incorrectly and will cause the P0011 code)
Cam Angle Sensor - Have a new sensor in the mail to see if the sensor is operational.
Timing - Both cam gears line up with the marks on the cover
Oil Pressure Sensor - Ordered a new pressure sensor switch beacuse I verified that there was the correct oil pressure with my aftermarket gauge.
Boost Leak Test - STOCK IX MR BOV FAILS AT 8 PSI With the recirculation hose removed from the stock oem BOV I could not hold more than 8 psi on the entire system. The test was conducted on the inlet side of the turbo as described on this forum.
I am boosting 25 psi - 26 psi. Is it normal for the stock bov to be leaking that much? Would that cause the problems listed above? In theory that BOV should hold the pressure not leak at 8 psi. What are your thoughts? Do you recommend any further tests before I throw in the towel?
Thanks for all of your help..
Mick
Old Dec 27, 2008 | 07:36 AM
mick82907's Avatar
bump
Old Dec 27, 2008 | 07:46 AM
Smike's Avatar
I would see if the cam sensor fixes the problem first. A friend's Evo in MI had the same issue. Her car would not run and acted as you have described.
Simple fixes first in my book.
Good luck.
Old Dec 27, 2008 | 08:32 AM
mick82907's Avatar
Good luck.
I hope thats the case with me 0 thanks for your input
Old Dec 27, 2008 | 01:53 PM
mick82907's Avatar
I could only fill the system with 12 psi. I have an audible leak and I think I have pinpointed it coming from the turbo/exhaust manifold area. I tried using soap and water to find the leak but no luck. Any suggestions? I check the cylinder head for leaks with the soapy water and found nothing. I have a pit in my garage so I can stand underneath the car. I hear it on the passenger side more than the drivers side, but the oil pan is in the way.
Old Dec 28, 2008 | 06:03 AM
hempele28's Avatar
CHeck the two bolts holding the outlet pipe to the turbo. When I had an audible leak that is were it was coming from. The gasket had actually blown out.
Old Feb 2, 2009 | 08:32 AM
EnjoyDriving's Avatar
Out of curosity, did it fix your problem, Mick?
sabastian458
43
Nov 2, 2015 01:35 PM
Sheasta
Oct 9, 2015 12:56 PM
Sheasta
Sep 27, 2015 07:52 PM
miked420
Mar 5, 2012 06:13 PM
