VIII patch to reset fuel trims?
Old May 21, 2009 | 08:13 AM
Fast_Freddie's Avatar
Veteran: Navy
Would it be feasible to create a patch for the VIII guys to reset fuel trims via ECUflash or Evoscan instead of disconnecting the battery? This would be a very helpful mod! I am not a dissasembler and at most an intermediate user for both programs... If possible can the patch be available to the 006 and 0011 roms... I don't use map switching so I have no need for the 006 rom...
Old May 21, 2009 | 08:24 AM
SEEnoEVO's Avatar
^x2
Old May 21, 2009 | 08:41 AM
jrohner's Avatar
That would definitely be handy.
Old May 22, 2009 | 08:57 PM
jba3's Avatar
+1, I didn't know the VIII doesn't reset the fuel trims
Old May 23, 2009 | 09:08 AM
logic's Avatar
The IXs reset trims on a reflash, the VIIIs only reset when you pull power from the ECU.
I've always thought resetting the trims on a map switch (in tephra's modified ROMs) would be a reasonable thing to do, since presumably you're making a significant change with the switch.
Old May 23, 2009 | 09:25 PM
Veteran: Navy
^ Thats what I am saying... especially with scaling inectors...
Old May 23, 2009 | 11:41 PM
Mattjin's Avatar
7's are the same, only resets from the battery.
Old May 24, 2009 | 10:00 AM
jrohner's Avatar
I would think a variable could be changed that would force the ECU to boot up from the beginning the next time, clearing the trims.
Old May 24, 2009 | 12:58 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
If I have understood clearing of DTC completely, clearing CEL should reset fuel trims also, can you try sending MUT_FA, MUT_FC down the line, one of them should clear trims, cannot remember which one now, but both clear CEL, no harm testing them.
Old May 25, 2009 | 03:05 AM
acamus's Avatar
Mattjin can you test it?
i.e.
Send custom request FA
Send custom request FC
via EvoScan or via Custom Tab in MutMonitor.
Old May 25, 2009 | 04:23 AM
Mattjin's Avatar
Might give it a shot tomorrow. This will actually be very helpful with the LT trim discovery, saving me from disconnecting the battery each time.
Old May 25, 2009 | 10:49 AM
G20's Avatar
G20
Just tried and clearing cel in evoscan does not reset the fuel trims on my 05.
Old May 25, 2009 | 06:29 PM
Jorge T's Avatar
I cleared a DTC code today and the trims got reset. After a 10 minute drive I cleared DTC with no codes and the trims did not reset again. I'm thinking trims only reset if a DTC is triggered off then cleared. This was on a 03 VIII.
Old May 25, 2009 | 09:31 PM
acamus's Avatar
Thanx, ^ this is what I wanted to be tested. So it seems we need a patch. I will try to find some easy way, if there is one.
Old May 25, 2009 | 09:38 PM
Veteran: Navy
Thanks acamus... Sorry I didn't provide any help, I have been in Seattle all weekend...
