EvoScan RPM skipping
Old May 21, 2009 | 10:27 PM
fugiwara's Avatar
Question EvoScan RPM skipping
HI, I bought a new laptop w/ vista 64 bit, I am using evoscan 2.6 beta 11.
Every time when I log, the rpm will skip, meaning there will be missing rpm being recorded, ex. from 3353 rpm to 5409 rpm sometimes it even skip 3000rpm.
I disabled log super speed.
My tuners say b/c my laptop is too fast? (4g memory, intel core 2 dual 8400), I submit ticket to evoscan, still haven't hear back.
Please help me, very frustrated. thanks
Old May 21, 2009 | 10:49 PM
tephra's Avatar
disable multithreading
how many items are you logging?
Old May 22, 2009 | 07:03 AM
fugiwara's Avatar
you want me to check "disable multithreading"?
I am logging everything that was checked off in default plus I checked off knock sum, load calculated, boost, air volumn, afr map, I am thinking I should checked off more items
Old May 22, 2009 | 07:13 AM
fugiwara's Avatar
this is what part of logs looks like, look at how RPM skips from 4.5k to 7.4k, seems like no one has this problem, everyone is have problem like logging slow
3375 183.2 14.15269 71.6 22
3281.25 183.2 14.15269 71.6 22
3250 183.2 14.07936 71.6 22
3218.75 183.2 14.15269 71.6 22
3187.5 183.2 14.15269 71.6 22
3156.25 183.2 14.15269 71.6 22
3125 183.2 14.07936 71.6 22
3093.75 183.2 14.15269 71.6 22
3062.5 183.2 14.07936 71.6 22
3031.25 183.2 14.07936 71.6 22
3000 183.2 14.15269 71.6 22
2968.75 183.2 14.07936 71.6 22
2968.75 183.2 14.15269 71.6 22
2875 181.4 14.15269 71.6 21
2875 181.4 14.07936 69.8 14
3031.25 179.6 14.07936 69.8 12
3125 179.6 14.00603 69.8 10
3281.25 179.6 13.9327 69.8 7
3437.5 179.6 13.9327 69.8 6
3625 179.6 13.85937 69.8 5
4312.5 179.6 13.9327 69.8 7
4531.25 179.6 13.78604 69.8 7
7406.25 181.4 14.15269 68 22
7343.75 181.4 14.15269 68 22
Old May 22, 2009 | 10:13 AM
fugiwara's Avatar
I checked "disable multithreading" it still skips
Old May 22, 2009 | 07:27 PM
fugiwara's Avatar
help needed
Old May 22, 2009 | 08:30 PM
tephra's Avatar
maybe its a vista64bit thing.
i would try and talk to Hamish direct...
Old May 22, 2009 | 08:39 PM
fugiwara's Avatar
thanks tephra, you are always around to help.
actually I talked to Hamish today on msn messenger, he doesn't know why this happens...
I talk to a friend of mine w/ similar laptop and he is ok. I am gonna try logging w/ my old laptop see what happened.
should I log less items instead? it only happens under wot condition, when I cruise it logs normally, maybe under WOT, everything happens fast
Old May 22, 2009 | 08:49 PM
tephra's Avatar
yeah WOT you expect to see less rpm skiping, something you wont notice when cruising.
how many items are you logging - only need to log 5 or 6 really..
Old May 22, 2009 | 09:18 PM
sub7's Avatar
Try disable "Log Data to Screen" and log less than 10 items?
Old May 23, 2009 | 05:15 AM
asdfasdf128's Avatar
Originally Posted by fugiwara
help needed
shoot me a pm with your email bro. I have v. 2.6 beta 8 and will email it to you. Maybe since yours is a newer beta edition, the kinks arent fully worked out?
Old Aug 6, 2012 | 04:29 PM
stamen's Avatar
Hi guys,
how was this problem solved? it's happening to me, it skipped like 2000rpm. I logged 13 items (including o2 wideband and map/boost).
babaz7
Mar 10, 2016 07:17 PM
dana daray
Feb 22, 2016 05:46 PM
dsmchiz
Oct 1, 2015 11:14 AM
evo7girl
May 30, 2009 07:26 AM
ant_turbo
Mar 13, 2009 06:48 AM
