Logworks 2-byte load problems
Old May 27, 2009 | 04:08 AM
Darkevolution86's Avatar
Hi
I've got some problems whit login 2-byte in Logworks.
I can read 2-byte load in evoscan but in Logworks it clips at 350kpa!!!
I added this to the protocol.xml
<datachannel id="#00" name="loadmsb" selected="1" units="load" min="0" max="255" expr="x" type="0"/>
<datachannel id="#01" name="loadlsb" selected="1" units="load" min="0" max="255" expr="x" type="0"/>
and also i calculated whit this formular after the realtime log:
MC(ECU_Load;%;0;350) = ((loadmsb * 256) + loadlsb)*10/32
Somebody know what i have to do???
Thanks
Pascal
Old May 27, 2009 | 06:14 AM
l2r99gst's Avatar
Originally Posted by Darkevolution86
Hi
Thanks
Pascal
That 350 tells LogWorks that is the maximum scale you want for your channel. Change that to whatever maximum you want.
Old May 27, 2009 | 07:39 AM
It's not the maxium scale i want to change. The problem is that its login 350kpa all the time even at idle.
Old May 27, 2009 | 07:41 AM
l2r99gst's Avatar
Are you sure you have the right RAM variables setup in request 00 and request 01 in your MUT table for 2-byte load?
Old May 27, 2009 | 08:11 AM
I thinke so, because evoscan 2-byte load is correct
Old May 27, 2009 | 08:23 AM
l2r99gst's Avatar
Sounds like you have things setup right, then. It's been a while since I have done this, so I am going off of memory.
How does the data look from each of the data channels? Is that looking like it is changing OK? If so, then something may be wrong in your MC formula. For example, your datachannels show the units as 'load', but your MC formula shows the units as %. It may be something like that.
I know there is a thread somewhere in this forum on how to do this, although it looks like you have it right.
Old May 27, 2009 | 06:21 PM
nothere's Avatar
I'm guessing you just upgraded your xml?
Old May 27, 2009 | 11:11 PM
After i had upgraded the protocol.xml, i've got te loadmsb and loadlsb.
Loadmsb shows nothing while login and loadlsb is at 60 or something. After i added the calculation ecu_load appears and shows 350kpa.
Sometimes logworks even crash down.
Old May 28, 2009 | 05:26 AM
nothere's Avatar
my logworks is reading a strange load too. It started after I upgraded my ecuflash xml. I don't understand that relationship, but that is when it happened.
Old May 28, 2009 | 10:58 PM
Is there a possibility to log load calc on Logworks?
Somebody know the column or the calc. formula?
Thanks
tephra
Mar 31, 2024 01:17 PM
tephra
Nov 22, 2019 10:05 PM
Pd1
Oct 11, 2009 05:17 PM
shadow1
Apr 3, 2009 05:32 PM
andenbre
Jun 25, 2008 04:01 PM
