How do I remove the load an IPW caps?
Old May 29, 2009 | 06:34 AM
wreckleford's Avatar
I know JCSBanks has figured out how to get load to read over 380 and to get rid of the injector pulse width caps, but I don't believe the method has been posted here. I need to do this patch on a 90550001 ROM for pretty healthy car. If it has been posted can someone direct me please. I did a search but I haven't found anything too useful.
Old May 29, 2009 | 08:28 AM
jcsbanks's Avatar
The addresses to NOP are just a few bytes away from the ones I NOP in the SD conversion which has been done for this ROM. I don't have any of this info at work though.
Old May 29, 2009 | 08:37 AM
Is there a ROM posted anywhere where it has been done that I could do a code compare?
Old May 29, 2009 | 09:12 AM
jcsbanks's Avatar
Yes on the MLR, ECU forum I posted 90550001 SD. There is a download link there.
Old May 29, 2009 | 01:18 PM
Allright, I will take a look.
Old May 29, 2009 | 04:23 PM
John, I compared the SD90550001 to the standard 90550001 and apart from the NOP sections identified in the SD XML, I don't see anything different close by. What can I do now?
Old May 29, 2009 | 04:48 PM
Okay, I did some more searching and found this that you posted:
https://www.evolutionm.net/forums/ec...ng-guys-7.html
post 104.
Can you tell me what the maximum injector pulse width is limited to?
Old May 29, 2009 | 04:57 PM
kkarim's Avatar
Following addresses should be set to 0x0009:
22030 for fuel limit
22014 for load limit
IPW limit is actually limited by what injectors you are using, and what IPW your ecu would run in this exact situation at the max load of 380.
I've been reaching up to 400 loads, and fueling is still ok with those settings on 90550001.
Old May 29, 2009 | 05:15 PM
Okay, from the same thread I was able to deduce the location of the injector pulse width limiter also. I didn't know that thread was so full of info.
mrfred
Sep 28, 2009 01:53 PM
Ceddy
Jun 16, 2009 12:37 PM
snoop
Mar 23, 2008 09:55 AM
Ducks
Jan 26, 2008 12:35 AM
Noogles
Jun 16, 2006 10:24 AM
