Evo X Logging
Old Jun 24, 2009 | 02:20 AM
  #466
Sanci's Avatar
Excuse me my English not too good.
Evo X MR is for me, and I am useful evoscan-t.
I would like to know whether it may be log SST transmission temperature of oil.
Somebody knows it for this the can-id and the formula?
Thanks.
Old Jun 24, 2009 | 05:33 PM
  #467
crcain's Avatar
Originally Posted by mrfred
Is this the one that you tried? If yes, then there is something wrong with your setup because I know this Data.xml works. The proper way to get EvoScan 2.6b14 installed is to install v2.5, then drop the 2.6b10 files on v2.5, and then drop the 2.6b14 files onto v2.6b10. Did you do that?
https://www.evolutionm.net/forums/ev...ml#post7176324
Is this correct?
evo4mad describes how to install the beta like this:
Originally Posted by evo4mad
21st June 2009: EvoScan v2.6 Beta15.zip Download EvoScan Beta15 here(registered users only)
- You still need to install EvoScan v2.5 full registered version first. Available here.
Old Jun 24, 2009 | 05:49 PM
  #468
SiC's Avatar
SiC
Originally Posted by crcain
Is this correct?
crcain,
Beta 15 has a setup program and beta 14 was just the program file. So to install beta 15, just click on the file and let it install itself as long as you have 2.5 installed. For beta 14 you need to install 2.5 and put the beta 14 files into the install directory of 2.5.
Old Jun 25, 2009 | 08:52 AM
  #469
crcain's Avatar
Originally Posted by SiC
crcain,
So you're saying mrfred was wrong?
Once I read what mrfred wrote, I thought I had found my problem, because I did find it odd that beta11 included an executable and about 6 ".dll" files. While beta14 just had an executable and a data file.
So you are 100% sure that the install of beta14 is to just extract the executable and data file to a virgin 2.5 dir?
Old Jun 25, 2009 | 02:23 PM
  #470
SiC's Avatar
SiC
I'm not saying anyone is wrong, I'm just saying what I did.
BTW, why don't you just install beta 15? That comes with all the install files including the newest dll files and it creates it's own directory so it wont overwrite your previous 2.5.
Old Jun 25, 2009 | 02:38 PM
  #471
crcain's Avatar
So you successfully logged using beta14 by simply extracting the executable and the data file in a virgin 2.5 directory?
I will try beta15 in a day or two, but I'm simply trying to get clarication on conflicting methods of install of beta14.
Old Jun 25, 2009 | 04:35 PM
  #472
SiC's Avatar
SiC
I never used beta 10 so I never had those files on my PC.
Why don't you just go straight to beta 15, it's alot easier since it comes with an installer.
Old Jun 25, 2009 | 04:44 PM
  #473
Hiboost's Avatar
I just installed b15 and it worked fine in it's seperate install directory. I did import over a few XML file settings and put them in the order I usually log them in for easy review in excel. The 2 byte load doesn't seem to have a formula attached to it though, not sure what the range of values is for that yet.
Old Jun 25, 2009 | 10:01 PM
  #474
crcain's Avatar
It would be a lot easier if you would just answer my question.
Have you succesfully logged with beta14 by simply taking the beta14 executable and data file and replacing them with files from a _virgin_ 2.5 install? Yes/No.
You keep telling me to use beta15 because it has an installer and that is easy to use. My problem isn't knowing how to extract an archive to a dir buddy. What I am trying to figure out is if my experience in using beta14 and it not working is related to unclear requirements of how to get it up and running, or if it was some glitch on my end.
Unfortunately asking you simple questions is becoming painful!
Old Jun 25, 2009 | 10:06 PM
  #475
tephra's Avatar
unless 15 isn't working for you then forget about 14...
AFAIK 15 comes with a full installer - so you dont need to stuff around with installing previous versions then replacing the exe..
Old Jun 25, 2009 | 11:42 PM
  #476
GST Motorsports's Avatar
Raises hand!
Yes I have.
Old Jun 26, 2009 | 12:10 AM
  #477
onboost's Avatar
tephra,
i just tried to edit my orig 52360016 xml with the mode 23 stuff so i can log the factory settings but my stooopid vista wont let me. i have mode 23 enabled on my current tune (running a 52360018) and that is working fine. Are you able to help me?
i have teamviewer if that helps
Old Jun 26, 2009 | 12:34 AM
  #478
tephra's Avatar
save the .xml someplace else - then copy it manually into the ecuflash directory.
i think if you try to edit and save vista poo's itself!
Old Jun 26, 2009 | 01:25 AM
  #479
onboost's Avatar
you the man
Old Jun 26, 2009 | 07:52 AM
  #480
crcain's Avatar
Originally Posted by GST Motorsports
Raises hand!
Yes I have.
Thank you! That is all I wanted to hear. I guess something was wrong with my setup OR the addresses SiC gave me for the 52360016 rom were wrong. I'm going to switch to the 52360018 AND use beta15 and see if I can be successful.
