Evo X Logging
Old Mar 13, 2010 | 10:41 AM
  #946
Fourdoor's Avatar
Originally Posted by tephra
1) leave your car overnight, in the morning compare the temp sensor on the HUD to the logged item - as long as your car isn't/wasn't in the sun they should be the same - within 1-2C Did this already, temp difference is 5.5 deg C
2) not sure on the LTFT, look at the addresses for MUT0C/0D/0E (from memory are low/mid/high OR idle/cruise/high) I have 2380861B, 2380861A, and 238089FD in those locations on my MUTT.... not related to STFT or LTFT addresses I was given.
3) P0139 is slowly being worked on Bless you!
4) MAT is usually +5bytes from MUT11 no idea what "+5 byted from MUT11" means. Mut11 is 23808649
5) IPW = MUT21 + 20 Mut21 is 2380971D and Mut20 is 238045C1... No idea how to add two addresses together.
6) IDC you can calculate from IPW*RPM/1200 Just need to figure out #5 first
Thanks,
Keith
Old Mar 13, 2010 | 04:17 PM
  #947
SiC's Avatar
SiC
4) if MUT11 is 23808649 you need to add 5 bytes which will make it 2380864e
5) same as above but add 20 bytes to 2380971D
6) use the same address as your RPM (which is x) and use this as the formula
[IPW]*31.25*x/1200
If you don't have a hex calculator, you can use this handy online one.
Old Mar 13, 2010 | 04:20 PM
  #948
Deepseadiver's Avatar
Yup, you edit the file in notepad and save it. It will save in the same file format and file name that it had to start with. BEFORE doing this make a copy of the original and save it in a separate location just in case you screw up your edit you have a clean backup.
Keith
Thanks, I will see if I can finish it and go make some logs. Still what are the attached files for in the first post?
Old Mar 13, 2010 | 06:11 PM
  #949
SiC's Avatar
SiC
That's tephra's original mode23 software and the config files for it. If you're using evoscan you do not need them.
Old Mar 13, 2010 | 06:23 PM
  #950
Thanks
Old Mar 13, 2010 | 08:43 PM
  #951
Fourdoor's Avatar
4) if MUT11 is 23808649 you need to add 5 bytes which will make it 2380864e I will try 2380864E
5) same as above but add 20 bytes to 2380971D 2380973D
[IPW]*31.25*x/1200
I logged the LTFT and STFT given by Hamish and neither one works for me, constant 12.5 on LTFT and constant -25 on STFT... so should I try the numbers I pulled out of the MUT based on what Tephra said in response to one of my earlier questions about LTFT? Any idea what MUT address to look at for STFT?
Thanks,
Keith
Old Mar 13, 2010 | 11:56 PM
  #952
SiC's Avatar
SiC
Thanks,
Keith
Those are both max values for fuel trims, either your trims/scaling are really screwed up or you must be logging the wrong address.
Your LTFT idle should be 23804573 (MUT0C) and LTFT cruise should be 23804575 (MUT0D).
STFT should be 238088B0 (MUT0F).
The formula for both LTFT & STFT is (0.1953125*x)-25
Old Mar 14, 2010 | 06:54 AM
  #953
Fourdoor's Avatar
Do the different ROM ID's all have different MUT table addresses? It almost seems like my MUT table is messed up.
For MUT0C I have 2380861B, MUT0D is 2380861A, and MUT0F is 23808A21
I NEVER seem to be able to look up the correct data points on my MUT Table. Am I reading it wrong or is it possible for it to be totally wrong? In 55590006 I have the MUT address as 3F244.
Thanks,
Keith
Old Mar 14, 2010 | 07:14 AM
  #954
SiC's Avatar
SiC
Thanks,
Keith
Yes most ROM IDs between different years & regions all have different MUT numbers.
The MUT address for your ROM is 3f26c, that's why you are seeing incorrect numbers.
Old Mar 14, 2010 | 07:22 AM
  #955
Fourdoor's Avatar
All this time, when I was told "just look it up yourself, "mutxxxx" and it wouldn't work... I have been so frustrated, and probably driving other people nuts asking them to look up things for me when I should have been able to do it myself. I have been looking incompetent or lazy all this time due to an error in my 55590006 files address for the mut table.
Uggg.
Keith
Old Mar 14, 2010 | 07:00 PM
  #956
Fourdoor's Avatar
What would be a "normal" injector pulse width value at various conditions? I am getting 10 to 12 ms at idle and it shoots to 40.96 and flat lines as soon as I go WOT. This is on E-85 BTW.
Thanks,
Keith
Old Mar 14, 2010 | 07:33 PM
  #957
tephra's Avatar
~2ms @ idle
20ms @ pk boost
15ms @ redline
93oct/stock injectors
Old Mar 14, 2010 | 07:52 PM
  #958
SiC's Avatar
SiC
Thanks,
Keith
I think you're off there, IPW should be MUT29 which is 2380AA88 on your car.
Old Mar 14, 2010 | 10:57 PM
  #959
Help!
I am having a NSIS Error when trying to down load EcuFlash 1.4 (includes all openport drivers for the 2.0 cable)
First, I down loaded the WIN RAR progarm. Now when I download EcuFlash I save it to my desktop, but when I open or run the program this is what I get.
NISIS Error
Installer integrity check has failed. Common causes include incomplete download and damaged media. Contact the installer's author to obtain a new copy. More information at: http://nsis.sf.net/NSIS_Error
I went to that web site and it suggested to turn off my anti virus protection. I did and it still dose not work.
I have the older version of EcuFlash on a external drive 1.41, but I want to start fresh and put everything new my netbook.
Any Ideas on what's wrong?
Old Mar 15, 2010 | 01:03 AM
  #960
tephra's Avatar
why do u need winrar?
try downloading ecuflash again... maybe it got corrupted...
