Evo X Logging
Old Feb 29, 2012 | 07:42 AM
  #1081
jordo's Avatar
How are these applied?
Do I simply edit the 56890010.xml?
I am having the same issues.
Originally Posted by Hellfire0986
Big thanks to Golden for his definition files for EcuFlash.
I saw a few pages back the logging addresses for the 2011 Evo X with ECUID: 56890007. I tried to use the logging addresses on my 2011 with ECUID: 56890010, and it seems all the addresses were off.
I guess it makes sense given 56890010 inherits 56890009. It seems 56890009 and 56890007 have completely different definition files.
Does anyone know the logging addresses for 56890010?
Thanks again!
Originally Posted by razorlab
Code:
238087B4 Load
2380878C 2ByteRPM
2380875E PSIG / Boost
23808A93 Knock Sum
238088E0 STFT
23804573 LFTF Idle
23804575 LTFT Cruise
238088F1 LTFT in use
238087BA Load (MIVEC) and (Timing if IAT GT 75F)
2380873D TPS
23809631 Accel Pedel Position
23808A4F TimingAdv
23808B9D ActiveWGDC
2380869B Intake Air Temp
2380867F Coolant Temp
238086A1 Manifold Air Temp
2380AB40 IPW
23808FB0 MAF Volts
23809552 INVVT (Target)
2380955E EXVVT (Target)
2380958A INVVT (Actual)
23809596 EXVVT (Actual)
2380882F Speed
23808733 Battery
2380AB05 Barometer
23808A99 knock_adc_processed
2380AB37 knock_base
2380AB33 knock_var
2380AB39 knock_change
23808AA7 knock_dynamics
23808135 knock_flag
238086AD Front O2
238086B1 Rear O2
238045C5 Cruise Light
23808B9B WGDC Correction
23808823 MAF Hz
Old Feb 29, 2012 | 09:14 PM
  #1082
Golden's Avatar
You add something like this to your Mitsubishi EvoX Mode23 USA.xml.
Code:
    <ecu name="Mode23 2011 2 USA RA EVOX">
      <Mode2 name="Mode2" type="Data List Items">
        <DataListItem DataLog="Y" Color="" Display="2-Byte RPM" LogReference="2ByteRPM" RequestID="2380878C" Eval="3.90625*x" Unit="rpm" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="8000" ChartMin="0" ChartMax="8000" ScalingFactor=".1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Load" LogReference="Load" RequestID="238087B4" Eval="x*10/32" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="30" ScalingFactor=".1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="TimingAdv" LogReference="TimingAdv" RequestID="23808A4F" Eval="x-20" Unit="deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-10" GaugeMax="50" ChartMin="-10" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Barometer" LogReference="Baro" RequestID="2380AB05" Eval="x*0.07251887" Unit="psi" MetricEval="x/2" MetricUnit="kPa" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="50" Visible="False" />
        <DataListItem DataLog="Y" Color="#4b0000" Display="PSIG" LogReference="PSIG" RequestID="2380875E" Eval="(x/4*0.1953125)-[Baro]" Unit="PSIG" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-15" GaugeMax="35" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Knock Sum" LogReference="KnockSum" RequestID="23808A93" Eval="x" Unit="count" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Accel Pedal Position" LogReference="APP" RequestID="23809631" Eval="(x-32)*129/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="TPS" LogReference="TPS" RequestID="2380873D" Eval="x*100/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Active WGDC" LogReference="WGDC_Active" RequestID="23808B9D" Eval="x/2" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="IPW" LogReference="IPW" RequestID="2380AB40" Eval="x/1000" Unit="ms" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Injector Duty Cycle (IDC)" LogReference="IDC" RequestID="2380878C" Eval="[IPW]*3.90625*x/1200" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes="Injector Duty Cycle. A percentage of injector utilisation." Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Manifold Air Temp" LogReference="MAT" RequestID="238086A1" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="200" ChartMin="-10" ChartMax="200" ScalingFactor="1" Notes="Engine Coolant Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Coolant Temp" LogReference="ECT" RequestID="2380867F" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Engine Coolant Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Intake Air Temp" LogReference="IAT" RequestID="2380869B" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Intake Air Temperature" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Speed" LogReference="Speed" RequestID="2380882F" Eval="x*1.243" Unit="mph" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="250" ChartMin="0" ChartMax="260" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="STFT" LogReference="STFT" RequestID="238088E0" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT idle" LogReference="IdleLTFT" RequestID="23804573" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT Cruise" LogReference="CruiseLTFT" RequestID="23804575" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="LTFT In Use" LogReference="CurrentLTFT" RequestID="238088F1" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Front Oxygen Sensor" LogReference="FrontO2" RequestID="238086AD" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Rear O2" LogReference="O2Sensor2" RequestID="238086B1" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Battery Level" LogReference="Battery" RequestID="23808733" Eval="0.07333*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="3" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="InVVT (target)" LogReference="InVVTtarget" RequestID="23809552" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="ExVVT (target)" LogReference="ExVVTtarget" RequestID="2380955E" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="InVVT (actual)" LogReference="InVVTactual" RequestID="2380958A" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="ExVVT (actual)" LogReference="ExVVTactual" RequestID="23809596" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="MAF Volts" LogReference="MAF" RequestID="23808FA4" Eval="x/1024*5" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="MAF Airflow" LogReference="MAFgs" RequestID="23808FB0" Eval="x*0.02" Unit="gs" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="#90ff00" Display="External Wideband A/F Ratio" LogReference="WideBandAF" RequestID="WDB" Eval="x" Unit="a/f ratio" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="10" Notes="Plug in your serial port from your wideband oxygen sensor if you have one." Priority="1" Visible="False" />
      </Mode2>
    </ecu>
Old Mar 3, 2012 | 09:05 PM
  #1083
BigT's Avatar
Does anyone have the lines I need to add in so I can flash a 2012 and turn on Mode23? 58010005 I'm using evoscan 2.9.
Old Mar 3, 2012 | 09:22 PM
  #1084
richardjh's Avatar
goldenevo.com definition for 58010005 has mode23 items defined. That'll take care of the flashing side.
I don't have the logging items for ya, though...
Rich
Old Mar 3, 2012 | 10:19 PM
  #1085
BigT's Avatar
Rich
Ya, thanks. I didn't even realise that Golden had all of that defined already. I decided to read through the code and noticed. Kind of a "duhh" moment on my part.
Now to figure out what I have to do to evoscan 2.9 as the dropdown menu only shows Mode23 for 2011 and prior.
Old Mar 4, 2012 | 06:25 AM
  #1086
momostallion's Avatar
golden posted the logging addresses of 58010005 in post #1066 in this thread.
i took those and placed those in xml format for easy pasting in post 1071, but you can just download the zip i posted in post 1079 and paste the 2012 gsr xml into your \Documents\EvoScan v2.9\DataSettings\ folder and open evoscan and 2012 will be available.
Old Mar 4, 2012 | 01:15 PM
  #1087
BigT's Avatar
And this is one of the biggest reason's why I loved owning an Evo.... the people on this forum and in the Evo scene in general are ****ing awesome, starting from tephra , Golden, etc. and trickling all the way down. Thanks a bunch, momostallion.
Old Mar 4, 2012 | 03:49 PM
  #1088
no problem! i've owned my evo for just over a month now and i completely agree. i've essentially spent 75% of my free time reading these forums about anything and everything paying special attention to their posts.
Old Mar 4, 2012 | 04:22 PM
  #1089
richardjh's Avatar
A month? That means momo was disassembling his ROM within the first week or two of Evo ownership. Hardcore!
Rich
Old Mar 4, 2012 | 05:19 PM
  #1090
Rich
haha, pretty much. i joined this forum the weekend i got my car and started reading. i ordered an openport exactly 1 week after buying the car.
Old Mar 5, 2012 | 07:01 AM
  #1091
Daluv's Avatar
anyone know if the cruise control Up/Down can be logged? I use to do it on my subaru (usually a bitfield with a load of different switches) and was wondering if it can be done on my X.
also if the rear defogger can be logged as well...
thanx
Mart
Old Mar 5, 2012 | 07:34 AM
  #1092
Golden's Avatar
Yes, you can log both the "cruise light" and the "cruise switch". One is a momentary toggle and the other is an on/off toggle. i.e. One represents the actual switch being depressed and the other is the state of the cruise control.
I have not seen the defrost stuff. My guess would be that the ECU doesn't know about it. But if it does, it can be logged. I don't have that address.
I'll need your rom id to get you the cruise addresses.
Old Mar 5, 2012 | 07:38 AM
  #1093
Golden's Avatar
How to setup your EvoScan with addresses that I post:
Take these EvoScan definitions for the newer 2011's. Change the "RequestID" in each line. And change the "ecu name" from "Mode23 2011 2 USA RA EVOX" to something more appropriate for your rom. The Mode23 and EVOX have to be in there. I think they are key words for EvoScan.
Code:
      </Mode2>
    </ecu>
Old Mar 6, 2012 | 07:39 AM
  #1094
kevinlau288's Avatar
noobs question,
how to log with the evoscan and rom id 56920006
i can use ecuflash with the definition, but can not log
do i miss something?
Old Mar 6, 2012 | 01:41 PM
  #1095
nonschlont's Avatar
you take the request ID's/.xmls that Golden Edit: and Razor, so kindly provided, and when you open up the EvoScan prorgram, you will need to make sure the request ID's match up. If not, change the request ID in EvoScan, by (R) clicking on the item in question, then click edit data items, go down to request ID, and put in the proper ID for your rom. (click ok)
