Interesting read: Ford developing laser ingnition
Old Jul 17, 2009 | 10:10 AM
l2r99gst's Avatar
Just thought this was an interesting tidbit I came across...how about using lasers instead of spark plugs.
Old Jul 17, 2009 | 10:34 AM
Fast_Freddie's Avatar
Veteran: Navy
Seems pretty cool
blkmkIII's Avatar
how do you check if oneis bad with out burning a hole in the wall.
Old Jul 17, 2009 | 10:56 AM
Vigman's Avatar
That 's a real progress!
Cool read! Thx!
Old Jul 17, 2009 | 12:36 PM
honki24's Avatar
I agree, thanks. Of course we all see some issues, but I'm sure they're working on them
- lens material: quartz?
- carbon buildup
- vibration/temp effects on pulse laser
Old Jul 17, 2009 | 12:37 PM
logic's Avatar
I read about that the other day; it's interesting to consider both the efficiencies you could gain going that route, as well as how clever you could get with overall packaging. Suddenly, you don't have to accommodate easy servicing of the plugs, which means you can get a little crazier with head placement and orientation (*cough* boxer plug replacements *cough*).
From a tuning perspective, think of the tables it would add. Power, activation latency, duration, perhaps aim/position? (Actually, I can imagine a system that works a lot like fuel injection.) Some form of auto-calibration (ala printer heads) would be needed; those lasers will fall out of alignment over time. Copy-protection on aftermarket tunes would involve increasing power and duration so much that aluminum starts melting...
It's one less maintenance item, but think about how much servicing would cost.
Old Jul 17, 2009 | 02:11 PM
Jumperalex's Avatar
I am just waiting for the day for consumer level non-cam activated valves ... then you can REALLY play with placement and orientation. oh yeah and infinitely variable timing, duration, and more steps of lift (likely not infinitesimally adjustable lift though).
Old Jul 17, 2009 | 03:25 PM
l2r99gst's Avatar
Well, the Coates rotary head has been around for a long time. I think that is the ideal head. I don't know why OEMs haven't gone that route. It eliminates the entire valve train (cams, valves, springs, lifters, etc) and needs no lubrication/coolant from what I remember. Talk about a high revving, free flowing head. I think it's a great idea, but who knows the reasons behind why they aren't in production vehicles.
Old Jul 17, 2009 | 03:50 PM
gear head's Avatar
Nifty concept, the automobile has come a long way since carbs & point ignitions
Old Jul 17, 2009 | 06:12 PM
tephra's Avatar
sharks with fricken laser beams
Old Jul 17, 2009 | 07:38 PM
C6C6CH3vo's Avatar
Best way to improve ignition is with two plugs/cyl.
Old Jul 18, 2009 | 08:14 PM
mrfred's Avatar
I imagine that they want an arm-and-a-leg for patent licensing.
DetroitEvoIX
Jan 30, 2019 10:17 AM
Noe18
Apr 5, 2012 06:49 AM
Dont Try To Run
67
Sep 6, 2007 05:04 PM
NWEvoViii
70
Aug 26, 2007 06:40 PM
