Patch: Force OBD Inspection Pass (acamus, mrfred)
Old Nov 30, 2014 | 08:55 AM
  #346
kaj's Avatar
kaj
Originally Posted by BubbaKush
Anyone recomened a shop or someone who can install and load this program, I'm located about 45min North of San Fransico and I will pay well. I'm getting ready to have my car inspected from DMV then I need to get the car smoged. Im guessing you can plug a computer into the OBD2 and find out what codes needs to be patched?
basically you patch what's missing, i.e. if you have no cat, you will need to setup the rear o2, if you have no EGR, you will need to patch that, etc.
Old Nov 30, 2014 | 09:07 AM
  #347
BubbaKush's Avatar
Well when it comes to computers I'm a complete idiot. All I can do to a computer is screw it up so I stay away from them. The car is 2004 RS, has Buschur V-band exhaust and Buschur FMIC with upper and lower intercooler pipes plus intake. The car does have FP4r cams, Supertech springs and ARP head studs and 9 BOV rest is stock.
Old Nov 30, 2014 | 09:59 AM
  #348
kaj's Avatar
kaj
if you have a cat, you should be fine, though i'm not sure the effect those cams will have on your emissions. assuming you pass visual you should be good to go. none of that other stuff will effect how clean it burns.
Old Mar 1, 2015 | 07:04 AM
  #349
redSLed's Avatar
How are you guys generating patch tables applicable to specific ECU internal IDs? I have 96420008, but there is not a patch table coded for that internal ID.
This is the only part here that is tripping me up. The rest of the changes I'm not worried about. Thanks a bunch guys.
Old Mar 1, 2015 | 12:02 PM
  #350
CDrinkH2O's Avatar
You will need to convert to a Tephra V7 ROM like 96530706 before you can patch the smog settings.
See here: https://www.evolutionm.net/forums/ec...ml#post7597337
Old Mar 2, 2015 | 06:43 AM
  #351
redSLed's Avatar
Sounds good, I got it! Thanks again.
Old Mar 3, 2015 | 02:01 PM
  #352
envyno1's Avatar
Veteran: Coast Guard
Has anyone run into any problems with having the o2 sensor "not ready" even though the tune is enabled and set to pass?
Old Mar 3, 2015 | 06:32 PM
  #353
kaj's Avatar
kaj
Yup. So far, I have not found a fix.
Old Mar 4, 2015 | 10:12 AM
  #354
redSLed's Avatar
I thought I had actually got it but apparently not. I'm able to bring up the tables in Ecuflash, set every parameter correctly for supported and/or pass. After reflashing, my car doesn't pass the readiness test through my OBD scanner.
Old Mar 4, 2015 | 12:07 PM
  #355
kaj's Avatar
kaj
that's exactly my issue. so i have to put the car back to stock for smog. not fun.
Old Mar 4, 2015 | 01:17 PM
  #356
ronaldo9's Avatar
Can you not try the spark plug non fouler trick?
Old Mar 4, 2015 | 02:37 PM
  #357
kaj's Avatar
kaj
I would have but needed to smog right away. Will be doing that next time.
Old Mar 12, 2015 | 03:59 PM
  #358
Rough_draft's Avatar
Just to clarify on the 94170008 ROM you cannot just apply the patch you have to convert to tephra v7 then apply the patch? I did the patch step by step and I can control what's available or supported but cannot control weather they are in a ready state even the the tables are properly placed
I've read and read and searched any help would be appreciated
Old Mar 14, 2015 | 12:55 PM
  #359
CDrinkH2O's Avatar
Yes that is correct.
Old Apr 26, 2015 | 06:08 PM
  #360
Klaiceps's Avatar
Originally Posted by randallsrt
I fail emissions today with an EVO9 on Speed Density 2.0 3D tune (88592715). I only had 3 monitors that were ready and all other came back as "unsupported"
I even plugged my scan tool into that evo9 that failed and also my personal evo 9 that is also on the 2.0 SD which verified that only 3 monitors were even available and set to pass.
Although the obd Force Passed tables are already implemented into that ROM/XML, no matter what options I choose, nothing changes on my Scan Tool.
I did experiment with another buddies NON 3D speed density patched rom (88590015) and that seems to be working perfectly fine after I patched the XML to display those tables. At this point I'm tempted to just make an emission only tune in order to pass, then switch back to the 3D Speed Density. Unless of course someone has any ideas...
This is the same exact problem I'm having right now. I'm running a Speed Density tune. Internal ID is 88591715. Only 3 monitors show up as available on my scan tool and the rest are unavailable. Has anyone found a solution to this? Any help is greatly appreciated.
