Evo8 ECU in a 1G DSM in the works!
Old Mar 25, 2010 | 10:28 AM
  #286
eyebrowski's Avatar
Are you guys having any IAT heat soak issues with the sensor in the intake manifold? It looks like this is what all the Evo guys are doing.
Old Mar 29, 2010 | 04:36 PM
  #287
0xDEAD's Avatar
All mine are in the UICP. On the evo (speed density) and the two DSM's I have on speed density. My FWD below:
Old Mar 30, 2010 | 05:55 AM
  #288
Seijuro's Avatar
Any chance you could snap a pic of your IAT mounting on your DSM?
Old Mar 31, 2010 | 10:14 AM
  #289
907dsm's Avatar
Could someone please pm a price how much it would cost to make a harness for the Evo 8 ecu conversion??? Please and thanks
Old Mar 31, 2010 | 10:17 AM
  #290
eyebrowski's Avatar
I paid $169 for my professionally made custom harness.
You could do it for next to nothing, in true DSM fashion, if you make it yourself with a harness cut out of junk yard car and a blown 1G ECU (for the header).
Old Mar 31, 2010 | 03:30 PM
  #291
akrot's Avatar
Thumbs up
I just completed my adapter-harness for the Evo8-ECU in a 1G DSM. In ignition mode everything is fine - could not start the engine yet, dont wanna try without a downpipe attached
The car is a turbo-conversion based on a '92 eu-spec eclipse. I got the Evo8 MAF and the Evo8 injectors hooked up (MAF also via adapter-harness) combined with a Evo3 16G Turbocharger. My intention is that the car will run "well" on stock evo7/8 tune I'll report.
BTW: thanks for all the great information in this thread. i found everything i needed to know here
Old Mar 31, 2010 | 08:37 PM
  #292
Jack_of_Trades's Avatar
Is it just me or does it appear that the LICP signal is maxxed out at 302*?
Old Apr 1, 2010 | 11:25 AM
  #293
Nick carroll's Avatar
Arron and I did some base tunning last night on our 1g to evo 8 conversion.
car did: 257 whp 261 ft-lbs
pump gas 92 oct
Car consist of:
16g
rc 1000's
3" exh
evo 8 ecu
stock 6 bolt
Old Apr 1, 2010 | 12:03 PM
  #294
JohnBradley's Avatar
Have a question about setting base timing with this. Are you guys just locking it with EvoScan and setting the CAS?
Also we ran into a weird almost misfire looking gap at 6k exactly on a couple of pulls. No audible miss, but timing cleared it up kind of. The weird part is right around the same RPM the coolant temp goes wacky every pull. It will be consistent at 176 or so and then suddenly drop to 132 only to come right back up at 6500 to 176 or so.
Old Apr 1, 2010 | 03:17 PM
  #295
I just lock the base timing at 5* with evoscan's actuator test and adjust the CAS like normal. Works like a champ. I personally haven't had any BLIP issues so IDK what could be causing your anomaly,sorry I wonder if there is a ground loop or poor connection to the engine ground maybe? Not sure how it would only be affected at a specific RPM but I figured I'd throw that out there since its a sensor thing.
Old Apr 1, 2010 | 03:30 PM
  #296
merlin.oz's Avatar
JOT, I agree that does look like a system measurement/recording limitation there on that nice plot.
And you can work out roughly what the thermal delay time is from when the throttle was lifted. Good plot OXDEAD.
Old Apr 1, 2010 | 06:24 PM
  #297
merlin.oz's Avatar
Autronic use a VDO sensor, but I dont remember what it will read to.
Old Apr 1, 2010 | 10:44 PM
  #298
I'll look to see what it is, but we had used a Delphi sensor to log the tranny temps on Jeff's car. Read to 400 something.
Old Apr 3, 2010 | 11:14 PM
  #299
Also what ROM seems to be the normally used one?
I am running Nick's car on 94170015 right now.
Old Apr 10, 2010 | 10:45 AM
  #300
BlackMage's Avatar
Well sorry to be inactive for so long, I just caught up with the thread. Saw the ISC B coils were backwards and fixed it on my tables. I'm a pay check away from getting EvoScan and OpenPort 2.0 connector. I ordered a 2G knock sensor from Mitsu that'll be here Tuesday. Also I got my car on the road finally after putting a FMIC, Evo III 16G, used alt, and 3" exhaust on it just to have the alt crap out on me 3 days later and have the car back down.
