ECU flash help
Old Jul 31, 2009 | 12:25 AM
bwracing00's Avatar
03 evo 8 ecu in 00 eclipse help
ok i drive a 2000 mitsubishi eclipse i tried searching i got nothing. this is my problem
im running a dual ECU setup 2000 ecu stock that cannot be flashed and then an 2003 evo 8 ecu with the boomslang harness i just dont know why its not reading it i cant start the car with this ecu hooked up becuase the Immobilizer and really i dont want to pay 5-600 for AMS to take a look i liek that satisfaction fo being able to tune and work on ym car myself but this 1 is really stumping me if anyone knows what i can do please let me know.
im going to check all the wires again tommorow to make sure they are going to the right slots in the pinouts maybe 1 got crossed or what not.
the evo 8 ecu is MN132874 code i searched it and it says its and 03 correct me if im wrong. please i need help its the only thing holding me back and i want to drive my car at least once this summer and then bring the car to MOD and by the looks of this if i dont get it running i wont be going. so anyone at all know anything post it up thanks brandon
Old Jul 31, 2009 | 09:43 AM
bwracing00's Avatar
anyone have any idea im checking the wiring today so if that works ill post it up if not i would really like some advice and i have searched and searched i cant find anything that has straight to do with this interface error on it i saw what other people have tried it doesnt work either.
Old Jul 31, 2009 | 10:38 AM
JohnBradley's Avatar
What version of the cable are you using? Did you make sure to install the cable AND the bootloader? I believe it does it automatically but cable issues typically are driver related. Other than that the read write connector or whatever the wire swap you need to do with a 3G (I can tell you on a 2G its like 4 wires) might be off. You definitely have an 03 ECU, but it doesnt matter since the protocol is the same for 03-05s.
Old Jul 31, 2009 | 11:29 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Looking at the log of ECuFlash, I see you are using some USB-Serial cable.
It migth be a silly question but does your cable support 15625 baud?
Or is it with OpenPort with wrong firmware
Old Jul 31, 2009 | 05:55 PM
bwracing00's Avatar
yes i had the cable plugged in when i installed it either way it gets installed either plugged in during and or after install
im gonna be calling up the company tommorow because i shouldnt have to deal with that but i want to look at it myself so im going through the wires now its just hard i dont want to pull anyout and not be able to get them back out.
how can i check if it supports the 15625 baud?
Old Aug 1, 2009 | 04:05 AM
acamus's Avatar
Can you post brand and model number of your cable?
Broke4speed
Aug 6, 2017 07:57 PM
06AznEvo
Oct 8, 2013 09:14 PM
Kalivar
12
Oct 19, 2012 07:07 PM
SLO-EVO
Aug 19, 2011 02:19 AM
nudge120
Jan 18, 2010 09:03 AM
