Comments on Tephra's Gear-based boost control w/ mrfred's direct boost mod
Old Aug 10, 2009 | 10:03 AM
Asmodeus6's Avatar
If your tables are slightly higher than needed and you let it downward correct ever so slightly - no... it will still do what you want and be pretty flat. Fine line though. I mean a LITTLE higher on GOOD dialed tables. Before anyone throws a hissy fit about what I just posted. I'll try the TPS portion. Bryan knows his ecu boost control. He's been doing it a long while in great volume.
Old Aug 10, 2009 | 10:43 AM
scheides's Avatar
EvoM Moderator
Yup I hear ya, I have been using ecu-controlled-boost for almost two years and its always been 'pretty flat' ....my point is that this gear-based setup is taking 'pretty good' and making it better; evolution, or a new milestone in a long line of small amounts of progress, if you will
Old Oct 21, 2009 | 04:26 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Scheides very good job I know this is an old post but I just found it. I think my Christmas present to myself will be GrimmSpeed 3 port Solenoid(my tuner used on on load based boost and now prefers it over Pierburg and GM 3 port), Omni 4 bar MAP, Tephra V7, and MrFred....btw your boost curve looks nice and smooth love it!
Old Oct 21, 2009 | 06:02 AM
rolly1818's Avatar
Registered User
can anyone post a table of what their gear/boost crossover looks like?
Thanks
Old Oct 21, 2009 | 06:20 AM
scheides's Avatar
EvoM Moderator
what do you mean crossover? Just dial in your boost in third gear, then pull a bit of WGDC out of the upper gears, and maybe add a little to the lower gears, you're set!
Old Oct 21, 2009 | 08:56 AM
rolly1818's Avatar
Registered User
the actual table with the RPM/SPeed to gear.
i never used it before
i need to know the general idea so i can do one for the 5 speed and 6 speed.
Old Oct 21, 2009 | 09:11 AM
95630706's Avatar
I have a little 16g TME', a 2.0, mild cams and stock muffler. This gets me a quick spike up to 21PSI @ 3.5-4K in 3rd and a nice plateu all the way to 6k and a taper to 19. All gears have a similar profile.
Probably not to different if you have a stock-ish set up. And yes it ****ing rocks!
Old Nov 16, 2009 | 08:56 PM
D-VO's Avatar
Thanks
Here's the one I made for an EVO that had a 5 speed tranny and 245/45/17 tires :
What I did was take a log of each gear for at least 3 seconds, then divided avg rpm by avg speed. Say for instance you get an average speed of 35 mph and average rpm of 4000 while making a pull in 3rd. (4000/35 = 114.286) So now you'd input 114 into the 3rd gear row.
BTW: I copied the value from 5th gear for 6th in an attempt to fix an issue, and copied the 1st gear value into 0 gear row to allow for full boost when using the launch maps.
mrfred
12
Jun 7, 2015 07:35 AM
FlintownKilla
Oct 11, 2012 12:40 PM
03whitegsr
Oct 17, 2009 10:20 PM
house_of_senate
Oct 5, 2009 04:33 PM
scheides
Feb 17, 2009 04:46 PM
