NY:need help with ecu !!!
Old Nov 16, 2009 | 08:22 PM
hediki12's Avatar
hey ok for those who dont know. i met in a car accident about a month ago totaled my car (icon avatar) and just got another 2g dsm (talon). so i took the ecu (evo 8) out the old car and put it in this yesterday and no matter what i did it wont connect to evoscan or ecuflash .. i tried 2 cables and 3 laptops and 3 different versions of both softwares... so my conclusion ecu got banged up pretty bad in the accident and is now shot...... the car has evo injectors and a 16g turbo the flash that on the ecu is tephra 5.10 and scaled for 450cc (stock dsm injectors) now its running pig rich wont idle properly because of the cams and injectors... did a pull for the hell of it and no check engine light flashed .. im thinking that it didnt flash because the ecu is barely able to run the car and the mods are just a no go. so no flash cel on knock .. so i was wondering if anyone in ny nere or in westchester would like to swing by put in the evo 8 ecu just to make sure that mines is dead... and swap mines in there to make sure its dead so that i can confirm it and buy a new one... as well as there laptop and cable... thanks for your support and help in advance!!!!!
Old Nov 17, 2009 | 04:48 AM
3gturbo's Avatar
You need pin 79 to flash check that its installed on your car.
Old Nov 17, 2009 | 05:21 AM
hediki12's Avatar
i have that not...... my 1st time swapping the ecu. it wont log either ... so not only flashing.
evoscan
52
Jun 20, 2017 01:46 AM
Jake26
85
Apr 30, 2013 11:42 PM
im_Zer0
13
Mar 3, 2012 09:34 AM
BoostN
Nov 4, 2006 08:42 AM
