Omni 4 bar MAP sensor ROM compatibility settings for USDM Evo 8/9
Old Oct 11, 2009 | 05:12 PM
  #46
donour's Avatar
bump to check my math.
Old Oct 11, 2009 | 06:17 PM
  #47
mrfred's Avatar
I think your math is correct. After looking at OMNI scaling formula again, there is a 0.5 psi positive offset in the reading, so 0.5 psi has to be subtracted to get the actual pressure. I'll get around to updating the first post soon.
Old Oct 11, 2009 | 06:29 PM
  #48
donour's Avatar
So I'm right in assuming the 10bit ADC is linear in the 0-5v range and the MUT value is that with the 2 LSBs shifted out?
d
Old Oct 11, 2009 | 06:38 PM
  #49
mrfred's Avatar
d
Yep, it is linear, and the 8 bit value is created using shll2. :-)
Old Oct 15, 2009 | 01:39 PM
  #50
EvoDan2004's Avatar
i have a question.
i have the jdm map now and am going to the omni. i got everything in ecuflash all setup. but it says to add this
<DataListItem DataLog="Y" Color="" Display="OMNI MAP" LogReference="OMNIMAP" RequestID="38" Eval="FORMULA HERE" Unit="psig" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-15" GaugeMax="35" ChartMin="-15" ChartMax="35" ScalingFactor="1" Notes=""/>
to evoscan. my question is if i did this already for the jdm map is it the same as the onmi or do i have to remove the jdm one and reinstall the omni??
Old Oct 15, 2009 | 03:30 PM
  #51
Evokid03's Avatar
thanks
Old Oct 16, 2009 | 07:10 AM
  #52
EvoDan2004's Avatar
bump for a answer to my question 2 posts up.
Old Oct 16, 2009 | 08:57 AM
  #53
JohnBradley's Avatar
Dan, clone it and alter the scaling if you log cars that might use the 3 bar.
Old Oct 17, 2009 | 08:35 AM
  #54
SeanV's Avatar
MrFred,would it be possible to use this universal Omni 4Bar Map Sensor over http://www.omnipowerusa.com/product.asp?P_ID=158
And get it to work on a EDM Evo8 using Tephra's latest 96530706 ROM, instead of using the Evo specific, intake manifold map sensor?
And also have Evoscan log it in BAR.
Thx
Old Oct 17, 2009 | 02:51 PM
  #55
mrfred's Avatar
Thx
Yes, that sensor will work fine. Same scaling as the Omni sensor with the Evo form factor.
Old Oct 29, 2009 | 08:01 PM
  #56
L@Ncer06's Avatar
Hey guys well i was wondering if i get the Omni 3 bar sensor can i use the jdm map scalings?
Old Oct 30, 2009 | 07:48 PM
  #57
mchuang's Avatar
So is the new equation 0.2369*x-(b-.5)
Old Nov 2, 2009 | 06:16 PM
  #58
donour's Avatar
I maintain that the one I posted is actually closer (0.2340x - b + 0.5), but yeah.
d
Old Nov 15, 2009 | 12:25 PM
  #59
PlanoEvo's Avatar
Awesome a no gauge option very cool!
Old Nov 20, 2009 | 01:32 AM
  #60
SeanV's Avatar
Bump for this question...
I also have the Omni 3Bar Map sensor and want to know which scaling/formula I should be using.
The same as the JDM 3Bar?
The same as the GM 3Bar?
The same as the Omni 4Bar?
None of the above , if so, which one?
Thx
