Omni 4 bar MAP sensor ROM compatibility settings for USDM Evo 8/9
Old May 26, 2010 | 02:50 AM
  #91
leecavturbo's Avatar
Originally Posted by And
i'm logging this sensor in evoscan with the assigned formula in psig, and I want to convert this to bar, so I multiplied this by 0.069 to give me bar,
When the engine isn't running I get 0 on both evoscan and my boost controller, but when the engine is idling I'm getting -0.5 in evoscan and -0.3 on my controller i haven't check the max boost yet but can anyone confirm the calculation I have is correct?
Thanks
Andy
i get different negative values too And. but 0 and positive figures match so i'm not bothered
Old May 26, 2010 | 09:36 AM
  #92
donour's Avatar
Thanks
Andy
1 bar is 14.5 psi, so your calculation is correct. The readings will depend on your altitude and the weather.
d
Old May 26, 2010 | 09:52 AM
  #93
RoadSpike's Avatar
Say wouldn't it have been easier to just directly convert the voltage into 4 bar?
So lesse quick formula would be.
5 volts equivalent to 255 x (x/255 = volts)
Sensor range 0 to 5 volts so whole range used. (no offset)
BAR = x/((255*5)/4) = x / 318.75
If you wanted 0 bar to be atmosphere pressure you could just subtract 1 at this point
Old May 26, 2010 | 10:52 AM
  #94
donour's Avatar
It is offset.
d
Old May 26, 2010 | 10:53 AM
  #95
RoadSpike's Avatar
Originally Posted by donour
It is offset.
d
Thats news to me what were the voltage ranges?
Old May 26, 2010 | 11:50 AM
  #96
donour's Avatar
From the omnipower directions:
P= pressure in KPA 4 bar = 400 KPA
Voltage out/signal = 5 X (.002421 X P - .00842)
Atmosphere equals 1 bar or 100 KPA = 5 X (.002421 X 100 - .00842) = 1.168 volts @ 1 bar or 100 KPA
That's why I posted a corrected formula way back at the beginning of this thread. The one in mrfred's post is slightly off.
d
Old May 26, 2010 | 11:54 AM
  #97
RoadSpike's Avatar
d
Ah thats really interesting i thought the sensors weren't offset like that.
Old May 26, 2010 | 11:58 AM
  #98
donour's Avatar
That was the point of post #43. A lot of folks seems to be using an incorrect scaling. Oh well...
d
Old May 26, 2010 | 12:03 PM
  #99
RoadSpike's Avatar
d
Doesn't seem to be offset by much though correct? looks like .5 psi or so?
Old May 26, 2010 | 12:28 PM
  #100
donour's Avatar
Yep.
d
Old May 26, 2010 | 07:28 PM
  #101
ace33joe's Avatar
Although it may be only a small offset, do we change all 3 scalings to something like these?
PSI8a Omni 4 bar =
ROM to Display = x*0.2340/2+0.5043
Display to ROM = (x-0.5043)/0.2340*2
PSI16a Omni 4 bar =
BoostErrorPSI Omni 4 bar = (Assuming ~0.5 psi offset is eliminated by substracting two PSI values)
ROM to Display = (x-128)*(0.2340/8)
Display to ROM = x/(0.2340/8)+128
Also EVOscan formula is now changed to =
0.2340*x + 0.5043 - 14.7
(Assuming 14.7 psi atmosphere pressure)
Old May 30, 2010 | 09:54 AM
  #102
And's Avatar
And
PSI8a Omni 4 bar =
PSI16a Omni 4 bar =
are these the values I should now be using?
thanks
Old Aug 5, 2010 | 03:59 AM
  #103
Mr.Nik's Avatar
Why are the settings for the JDM MAP (3 bar) and Omni 4 bar the same?
MAP Test 1: Mid VE High Voltage Test -- Change from 4.61 volts to 4.90 volts.
MAP Test 1: Mid VE Low Voltage Test -- Change from 0.10 volts to 0.06 volts.
MAP Test 3: High VE Voltage Test -- Change from 1.80 volts to 0.51 volts.
Old Aug 5, 2010 | 09:35 AM
  #104
RoadSpike's Avatar
Those tests are for when the sensor goes out of range like unplugging it, shorting it, etc. It doesn't really do much else :P.
Old Aug 6, 2010 | 07:19 AM
  #105
Mr.Nik's Avatar
RoadSpike,
Thank you. I understood everything.
Another question: what else can I do with Omni 4 bar sensor and the stock ECU?
By what formula to Evoscan 2.7 to calculate the pressure in the bar?
