The DTC Disable thread (P1235, P1241, P1238, etc)
Subscribe
Sep 16, 2009 | 01:24 PM
  #91
Yeah I have no more problem been running this way for awhile now and I VTA on my stock BOV. Just want to say thank's again for your hard work. Now disable them LTFT that affect WOT.
Reply 0
Sep 16, 2009 | 11:54 PM
  #92
Quote: Had a little time on my hands why should we make Tephra do all the work
09 MR 54070007
<table name="DTC P1238 Disable 0x0384 -> 0xFFFF" category="Misc" address="63210" type="1D" scaling="Hex16"/>
<table name="DTC P1241 Disable 0x03E8 -> 0xFFFF" category="Misc" address="63206" type="1D" scaling="Hex16"/>
<table name="DTC P1235 Disable 0x0026 -> 0xFFFF" category="Misc" address="549D4" type="1D" scaling="Hex16"/>
<table name="DTC P1233 Disable 0x0028 -> 0xFFFF" category="Misc" address="549D0" type="1D" scaling="Hex16"/>
<table name="DTC P1234 Disable 0x0028 -> 0xFFFF" category="Misc" address="549D2" type="1D" scaling="Hex16"/>
<table name="DTC P0247 Disable 0xF9DF -> 0xF1DF" category="Misc" address="937B2" type="1D" scaling="Hex16"/>
Cheers Cam
All of the above also check out for 54060006 except the PO247 I will post that later I left my notes at the office.
Reply 0
Sep 17, 2009 | 12:48 AM
  #93
thx Cam!
Reply 0
Sep 21, 2009 | 04:51 AM
  #94
DTC help
I am new to this, can someone post a how to for people like me. I am trying paste this into the xml file, but with no luck. pls post a step by step method on pasting this patch into my definition files
Reply 0
Sep 21, 2009 | 04:57 AM
  #95
Quote: I am new to this, can someone post a how to for people like me. I am trying paste this into the xml file, but with no luck. pls post a step by step method on pasting this patch into my definition files
Swing by around 10 a.m today
Reply 0
Sep 22, 2009 | 08:15 AM
  #96
Tephra,
I have an ECU ID 52690019 (09 MR). All of the addresses match except for p0247 which, in this code, equals "D12E".
Let me know what you think. I have a hex editor, but I know enough only to get me in trouble.
Thanks,
Chris
Reply 0
Sep 22, 2009 | 10:14 AM
  #97
Thanks,
Chris
Did you try the 53040010 address?
Reply 0
Sep 22, 2009 | 02:00 PM
  #98
Quote: Did you try the 53040010 address?
Hmm, that shows it as "0xF99F" I'm seeing "D12E".
Reply 0
Sep 22, 2009 | 02:02 PM
  #99
Quote: Hmm, that shows it as "0xF99F" I'm seeing "D12E".
When you put that XML line in you see F99F? Then it is correct
There is different XML for the two sets. Did you put the whole XML line in?
Reply 0
Sep 22, 2009 | 02:37 PM
  #100
Quote: When you put that XML line in you see F99F? Then it is correct
Other way around.. When I put the XML line in, I saw D12F
Reply 0
Sep 24, 2009 | 04:50 PM
  #101
No solution for Rear O2 sensor codes yet? Is there anything you'd like me to log to help out? I'm running ROM ID 21
Thanks!
verkion
Reply 0
Sep 26, 2009 | 08:49 AM
  #102
Would be happy to send a few bucks to someone who can help with the addresses for romid 52360016. I got a buddy with a X who could really use it.
Reply 0
Sep 26, 2009 | 06:03 PM
  #103
send me the rom ill take a look tommorow...
<me> @ gmail.com
Reply 0
Sep 27, 2009 | 11:02 PM
  #104
xml for 52360016 added in post #1
Reply 0
Sep 28, 2009 | 09:09 AM
  #105
Thanks tephra paypal sent!
Reply 0
3  4  5  6  7  8  9  10  11  17
