Best 2 Step Settings
Old Sep 10, 2009 | 07:15 PM
  #31
Appauldd's Avatar
Originally Posted by house_of_senate
Mine is at 160ish load to 200 load, and whatever rpm I have it set at.
WOW....so in decreasing the timing in this area we end up with a big "hole" in the table. Seems like that might cause major drivability issues.
I read the entire thread and there is mixed opinions. Any explanation of the effect your be appreciated.
Paul
Old Sep 10, 2009 | 08:16 PM
  #32
rolly1818's Avatar
Registered User
Paul
not really its highly unlikely u will be @ 160 load at 5500/6000 rpm.
Old Sep 10, 2009 | 08:23 PM
  #33
Jeff_Jeske's Avatar
I really don't think you need to treat your street car like a rally car with antilag. Unless you have a monster turbo -10 is way way too much.
As for the AFR... it seems that the more fuel you add the faster the recovery. Again I don't think you need to go much more aggressive than stock.
Old Sep 10, 2009 | 08:39 PM
  #34
9sec9's Avatar
I agree 100%. We use 160/180 load cells and rpm on high and low sides of 2step rpm. 8 in the 160 and 9 in the 180 is a good compromise for us. Tonight Indy made 16-19 lbs of boost in 1.4 seconds but part of that was the pulled timing due to knock causing more boost, causing more pulled timing, causing more boost, then launch and 0 knock. Less than 1 second is all we really need but hard to judge when to go for the driver.
Old Sep 11, 2009 | 05:30 AM
  #35
rawkus's Avatar
Originally Posted by fostytou
Stock turbo wheel will be more resistant than, say, a TME... its still not great for it but it isn't necessarily the worst.
Don't you mean the TME would handle the heat better? I was under the assumption that was what the TiAl wheel was created for.
Dan
Old Sep 11, 2009 | 06:19 AM
  #36
fostytou's Avatar
EvoM Community Team
Dan
*facepalm*. My brain got that one one backwards yesterday. The compressor wheel is weaker, not the hot side. You are correct.
Old Sep 11, 2009 | 07:46 AM
  #37
rawkus's Avatar
No worries, but are you now saying the compressor wheel on the TME turbo is weaker than the factory VIII turbo? I was under the assumption that they shared the same compressor wheel. I could very well be wrong. Thanks.
Dan (Currently uses TME Turbo)
nicolassabra
Jun 7, 2013 06:01 PM
EvoPower81
Oct 16, 2010 07:39 PM
High_PSI
34
Dec 27, 2006 05:08 PM
DallasN2O
22
Jun 10, 2006 09:46 AM
