Speed density + NLTS patch??
Old Aug 24, 2009 | 07:15 PM
RyuEvoIX's Avatar
Is there anyone that knows of an 88590015 speed density rom that also has the NLTS patched onto it as well? If not does anyone have the know how to add it into the existing Speed density patched rom? I understand it is supposed to be added in the Tephra V7 patch but nothing has been posted yet on a release date. I highly value that patch and now that I have converted to a speed density rom I am in dire need of getting the NLTS back on the car.
Old Aug 25, 2009 | 11:04 AM
RyuEvoIX's Avatar
Bump for help
Old Aug 25, 2009 | 11:16 AM
JohnBradley's Avatar
You are overthinking it like I did. Take your NLTS ROM and then change the SD programming and Tuning parameters to match your current SD ROM. Make sure to change the SD Baro setting in the Tuning section as well. Then reflash and enjoy.
Old Aug 25, 2009 | 04:44 PM
RyuEvoIX's Avatar
Wow, I guess I was over thinking it. So just copy and paste my settings from my SD rom to my V5 patched rom and I'm good to go?
Old Aug 25, 2009 | 06:22 PM
Yes, both the tuning portion and the part labeled as "programming" also.
Then it works.
aaron
Old Aug 25, 2009 | 06:31 PM
RyuEvoIX's Avatar
Then it works.
aaron
Thanks John. Your a life saver.
Old Aug 25, 2009 | 06:40 PM
No worries Thats why I am here.
Old Aug 27, 2009 | 08:18 AM
dmoevo's Avatar
shouldnt your "stock ecu expert" tooner know this?
Old Aug 27, 2009 | 08:28 AM
Ph3n1x's Avatar
Good info JB
Old Aug 27, 2009 | 08:36 AM
RyuEvoIX's Avatar
Ah, another AWD Motorsports Troll. You never see any of the TTP guys hoping in threads just to try and take stabs at the guys at AWD. I guess were a bit more mature. Good job at poorly representing your shop of choice. I'll be sure to let Scott know who to thank for sending more business his way.
Old Aug 27, 2009 | 08:40 AM
RyuEvoIX's Avatar
Originally Posted by Ph3n1x
Good info JB
Absolutely. JB ftw.
Old Aug 27, 2009 | 08:50 AM
dmoevo's Avatar
Ah, another AWD Motorsports Troll. You never see any of the TTP guys hoping in threads just to try and take stabs at the guys at AWD. I guess were a bit more mature. Good job at poorly representing your shop of choice. I'll be sure to let Scott know to thank you for sending more business his way.
well cause there really isnt anything to stab at. it was merely an observation. good to see that the boards can be a source of information
Old Aug 27, 2009 | 09:46 AM
Oh this should go without saying of course, but then you'll need to take the TUNE and put in the NLTS ROM as well
Old Aug 27, 2009 | 04:35 PM
RyuEvoIX's Avatar
Ofcourse. I did run into a bit of a snag though. I transferred every single map from my newly tune SD rom to my V5.1 rom and its nearly perfect except for one minor issue. When I am at very light throttle, approx. 25% just enough to maintain my cruising speed the car jumps lean as if its going into fuel cut and will decelerate until I increase throttle position. It's quite puzzling. I loaded my tuned SD rom from TTP back in and no issues. Everything else seems to act exactly the same though.
Old Aug 27, 2009 | 06:14 PM
lillev23's Avatar
So you still dont have the NLTS?
