close loop timing vs open loop timing
Old Aug 29, 2009 | 09:23 PM
hediki12's Avatar
i was looking over some logs and im puzzled none of the closed loop stuff seem to follow the timing maps.... light cruise i will see some time 40-45* of timing... when my map says no more than 38*. and when i go wot it follows it exactly... idk... does the ecu advance timing in closed loop if it sees fit?
Old Aug 29, 2009 | 09:34 PM
tephra's Avatar
Egr
Old Aug 29, 2009 | 09:39 PM
GST Motorsports's Avatar
EGR advance map
Old Aug 29, 2009 | 09:42 PM
hediki12's Avatar
Old Aug 29, 2009 | 09:43 PM
hediki12's Avatar
hmmm egr advance map. ill look at it now. thanx.
Old Aug 29, 2009 | 10:02 PM
hediki12's Avatar
ok i tried searching on it and im not quite sure of its purpose can some one elaborate a bit?
Old Aug 29, 2009 | 10:16 PM
hediki12's Avatar
ok i think i found a fix https://www.evolutionm.net/forums/ec...your-maps.html
Old Aug 29, 2009 | 10:18 PM
tephra's Avatar
that will only subtract timing from your ignition map, not add it in
EGR adds timing.
google EGR to understand what it is first
Old Aug 30, 2009 | 03:02 PM
hediki12's Avatar
EGR adds timing.
ok will do, but i mean i kinda want it to subtract timing. because it just seems to keep ramping it up and then i get knock when the conditions change . i knock a drastic change will cause knock so it my ecu is raping up the timing now that i add a little more throttle the timing change is too agressive. like from 46* to 26* in less than 1k and 20 load.... i mean does that make sence?
Old Aug 30, 2009 | 03:08 PM
03whitegsr's Avatar
You can disable the EGR advance through the periphery bits. I wouldn't do it unless you disable the EGR valve functions/checks as well.
Depending on the RPM range and engine load you experience the problem, you may just be getting "phantom knock."
Probably has nothing to do with the higher advance. It's pretty hard to get a low compression motor to detonate without high engine loads.
Old Aug 30, 2009 | 03:48 PM
hediki12's Avatar
kool thanks can you show me a link on how to disable the egr? im searching like hell now and most of the stuff im getting is egr plate / removal. and blah blah blah.
Old Aug 30, 2009 | 03:54 PM
You can just put zeros in the EGR advance table
Alchem1st
Jul 28, 2017 01:15 PM
5LEEPERISAH23I
Mar 7, 2016 12:04 PM
10isace
E85 / Ethanol
Mar 20, 2013 06:31 PM
rrkpitt15
Sep 16, 2011 09:40 AM
