Can bad fuel cause knock at cruise but not at WOT?
Old Sep 12, 2009 | 08:06 PM
  #31
tephra's Avatar
with the X there isn't any load cuttoff for the BCS... so it will work at idle - whatever you have in the table...
I just put 50% in, and its not that loud... ie the lifters are louder...
so i don't think that could be causing it either..
Car runs like normal...
Maybe when I hit boost cut I jumped a tooth or something on the cam gears??? I have noticed when *sometimes* during take off (1/2/3) the car makes a 'wheezing' sound... like the turbo is spooling, but I dont think it is..
I will need to correlate that with a log... next time I am out
Old Sep 14, 2009 | 02:16 AM
  #32
tephra's Avatar
hrmm so it seems to be knocky during the first 5 mins.... ie when the engine is still coldish...
any thoughts to that?
Old Sep 14, 2009 | 08:48 AM
  #33
laramie_05MR's Avatar
pistons slapping till they warm up?
Old Sep 14, 2009 | 11:36 PM
  #34
tephra's Avatar
Dunno.
update - I had a look down at the exhaust and the "thing" that I thought could have come loose hasn't.. (as far as I can see anyways)
I am going to pull the plugs - but my feeling is they will be fine... Post some pics soonish
Old Sep 15, 2009 | 01:55 AM
  #35
tephra's Avatar
anyone interested in seeing a log?
http://www.globalshare.net/evo/log.zip
load it up in excel and filter by knocksum (exclude 0KS) and you will see the magic lol
what's interesting is I don't have any major knock until the engine is 77degC, and then nothing after 425seconds..
So it's not really "cold start" problems...
Old Sep 16, 2009 | 05:39 AM
  #36
tephra's Avatar
bump for someone to take a look at my log
Old Sep 16, 2009 | 06:06 AM
  #37
mindoftw's Avatar
Hey i am having the same problem, except on my evo 8. Still trying to figure out what it is.
Old Sep 16, 2009 | 06:24 AM
  #38
tephra's Avatar
well CT9A has ALWAYS been knocky 2500/70ish load.
but CZ4A seems to be ok... well mine used to be fine, but now its doing it
Old Sep 16, 2009 | 08:23 AM
  #39
mrfred's Avatar
Not sure that there is anything to be learned. Have you looked at the knock code to see if its any different than the 8/9 code? Another thought that I just had is that it might be useful to loosen and then retorque the knock sensor on the block.
Old Sep 16, 2009 | 03:54 PM
  #40
tephra's Avatar
code is basically the same...
i need to pull the plugs still as well... so ill re-tq the sensor at the same time
Old Sep 17, 2009 | 08:02 PM
  #41
C6C6CH3vo's Avatar
I will get that part throttle knock no matter what octane is in there. It either knocks like crazy there, from head or piston noise, or ecu too sensitive at the area. It doesn't worry me too much.
jmrussell89
Oct 8, 2016 09:29 AM
evo_gerard
Jun 1, 2014 08:04 AM
joedr
18
Sep 8, 2010 07:29 PM
xpro
Feb 1, 2010 12:40 AM
tephra
Oct 22, 2009 03:46 PM
