warm up afr
Old Sep 25, 2009 | 05:10 PM
nothere's Avatar
warm up afr
has there been a way to control warm up idle? besides open loop .
maybe there is no way around a rich warm up? will the car even keep running if the afr is leaned down? (leaned up)?
Old Sep 25, 2009 | 05:18 PM
Jack_of_Trades's Avatar
Generally you WANT a richer mixture when the temps are cold (or the engine is cold). Usually you can adjust the MAF scaling or open loop areas in the fuel maps to lean it out if you need to. How rich are you running??
Old Sep 25, 2009 | 05:28 PM
nothere's Avatar
12...13 without a cat it tells.
Old Sep 25, 2009 | 05:42 PM
I assume you mean at idle, what is your LTFT Low? Stock injectors? Stock intake pipe?
Old Sep 25, 2009 | 06:00 PM
nothere's Avatar
oh yeah I'm only thinking in terms of warm up idle. once warm, all is fine.
fuel trims are good, but as I say, the ecu is adding fuel during warm up and i'd like to play with that. bosch1000 and the accordion.
dsmchiz
Apr 16, 2016 03:08 PM
dsmchiz
Mar 29, 2016 01:11 PM
Dakota Evo
Dec 7, 2015 09:46 PM
740 Turbo Brick
Oct 16, 2015 02:57 PM
sdanyow
Nov 13, 2013 01:35 AM
