LS disable for 94170015 ROM
Old Oct 1, 2009 | 12:37 PM
wtf_is_a_evo's Avatar
Forgive me if i looked over it but only thing i could find was for evo9s and the 0008 rom for evo8s.
I am using ecuflash version 1.42.
and rom is 94170015.
Anyone here know what i need to add or change to disable my LS.
Old Oct 1, 2009 | 09:37 PM
Raceghost's Avatar
Yes.
There is a thread in here about it. I forget what it is under.
Those tables are defined in the xml's that the guru's are checking out as we speak.
So as soon as they give the ok, that it looks good, and are willing to part with it, I will post the code for you, or send you the xml's, or Appauld can send you the supermega one.
Sorry if this is no help currently, but now you know the location.
EDIT: You can also disable the periphery bit, if you have those tables. That is also in both Appaulds and my xml's. Though no ownership on my behalf, i only cleaned it up, and slipstreamed it.
Old Oct 1, 2009 | 10:09 PM
Thank you i will look some more and keep a eye out for anymore info i can find.
Old Oct 2, 2009 | 07:01 AM
Appauldd's Avatar
The common "old" way to disable LS is to set the RPM values the same.
Personally, I like to have LS on. It takes a little longer to get a good tune, but the safety of LS helps a lot. There has been numerous discussions that LS really isn't "Lean Spool" but more of fuel adder. Thus the name LS is misleading.
Think about how the feature works.....The ECU will artificially richen up the AFR based on certain engine conditions. By adding fuel you are allding safety to the car avoiding lean conditions with rapid throttle transitions and such.
By road tuning in s the same location of flat land and doing so in about the same temperature of weather, you can accurately tune the car for great power. LS will keep safety in the equasion.
kiggly
Mar 14, 2016 05:29 PM
3gEclipseTurbo
Jun 2, 2011 07:58 PM
tscompusa2
Aug 27, 2009 07:56 PM
wantanevo2
Aug 19, 2009 05:06 PM
nj1266
Feb 20, 2009 08:37 AM
