Correcting a few 96530006 definitions
Old Oct 5, 2009 | 10:51 AM
logic's Avatar
These are what appear to be errors in the XML that ships with EcuFlash. For historical/search purposes, the version of EcuFlash I'm working with (and hence, the XML version) is 1.42, and might not (hopefully won't) apply to future versions.
Relative Air Density vs. Temp for Airflow/Hz at 333e:
The "Degrees" axis for this is listed as 69be (, but it looks like it ought to be 6af0. Values are different between axes. I've also seen this table referred to as "Air Temperature Compensation".
Desired ISCV initial step position with AC off-Drive at 4296, and
Desired Idle RPM-Neutral at 427a:
The axis listed is 6aa0, but it looks like 6a86 is correct. Axis values are the same, so it's not a big deal.
I would some extra eyes on this to confirm, though.
Old Oct 5, 2009 | 11:54 AM
scheides's Avatar
EvoM Moderator
Cool! Maybe this will help make idle more tweakable! I'll try it.
Old Oct 8, 2009 | 10:22 AM
Jack_of_Trades's Avatar
NVM, useless post.
Old Oct 8, 2009 | 10:24 AM
binky's Avatar
Originally Posted by Jack_of_Trades
NVM, useless post.
So they aren't backwards?
-Bink
Old Oct 8, 2009 | 03:00 PM
Actually, I browsed over his first post after I posted it and thought he already had that listed but I guess I was wrong lol.
DESIRED IDLE RPM-NEUTRAL
and DESIRED IDLE RPM-DRIVE are labeled backwards.
DESIRED IDLE RPM-NEUTRAL address = 426c
DESIRED IDLE RPM-DRIVE address = 427a
Old Oct 8, 2009 | 03:09 PM
logic's Avatar
Yep, you're right; good catch.
Old Oct 9, 2009 | 10:25 PM
03whitegsr's Avatar
I'm working on going through 96530006 as well and the Base EGR Pulse width tables looks incorrect as well. Original is Red, suggested is next to it.
I just started looking up the tables so I could be wrong though.
Code:
<table name="Base EGR Duty Cycle" address="46db">
        <table name="Load" address="6c9C"/>
	<table name="RPM" address="6d24"   6C7E/>
</table>
Old Oct 9, 2009 | 10:28 PM
03whitegsr's Avatar
Double post
logic
Nov 8, 2018 04:17 AM
mrfred
Dec 21, 2014 10:13 AM
Appauldd
Apr 13, 2011 01:37 PM
hackish
16
Dec 23, 2009 05:43 AM
Pd1
Oct 11, 2009 05:17 PM
