Tephra v7 9653 thottle hang
Old Oct 9, 2009 | 06:28 PM
  #61
phenem's Avatar
After comparing the tables the only tables that are different are the neutral A/C on and off tables. The other two decel tables are the same, no differences.
What's really the differences in these tables? Why are the Neutral tables the only ones affected and not the in gear ones? Weird....
Here is a picture of what I am referring to:
Old Oct 9, 2009 | 06:32 PM
  #62
0xDEAD's Avatar
You sure do make pretty pictures.
Old Oct 9, 2009 | 06:33 PM
  #63
phenem's Avatar
Well I guess that makes one thing I am good at!
Old Oct 9, 2009 | 07:34 PM
  #64
Evo_Jay's Avatar
Originally Posted by mfr122887
Changed the decel fuel cut tables to match those of 94170015 and the throttle hang is still present. It is not as bad, the RPMs fall slowly but the AFRs do not peg lean, they stay around 13-14.
Try making the "decel fuel cut delay" tables AND the "Idle steppe Look up table" match those of the 94170015.
Old Oct 9, 2009 | 07:37 PM
  #65
Evo_Jay's Avatar
Also do we have the
- ISCV Demand RPM Adder [rpm > 4500, load > 170, speed > 12 mph]
- ISCV Demand RPM Adder (Moderated by Baro, IATS) (FFFF6EA8) (sub_204B6) [sub_1EFC0]
defined for ROMS 96940011, 94170015 & 96420008, Or did I miss something?
Old Oct 10, 2009 | 10:47 AM
  #66
mfr122887's Avatar
I did this and the hang is still present. The RPMs are falling but not as fast as on 94170015 and the AFRs are not pegging lean. They bounce around between 12-16 until 3-3.5k RPMs then they go lean. Anyone know why they go lean at that point and not higher up in the rpm band?
Old Oct 11, 2009 | 07:21 PM
  #67
Appauldd's Avatar
And the v7 bugs are coming alive....AHHHHH
Old Oct 11, 2009 | 07:32 PM
  #68
fixem2's Avatar
Nope not considered a bug, since this issue tends to plague all 96530006 ROMS. This thread was started to find a solution that can be incorporated into the V7 ROM.
Old Oct 11, 2009 | 08:22 PM
  #69
simple_lancer's Avatar
mfr122887 maybe try checking your Base Idle Speed Screw to ensure you haven't wound it out too far. If you log the ISCV steps, it should be around 15 or so at idle when the engine is warmed up properly.
There is also another table you can try zeroing out to eliminate throttle hang.
- ISCV Demand RPM Adder* (sub_1EFC0)
I found that this affected throttle response so I left it standard.
I have been playing with my decel fuel cut tables, as I feel the stock 96530006 values are way too high.
Old Oct 11, 2009 | 08:28 PM
  #70
mfr122887's Avatar
I used the Evoscan actuator mode to set the biss screw. At idle, it moves between 14-17 steps so I think the screw is set correctly.
Old Oct 11, 2009 | 08:56 PM
  #71
nothere's Avatar
is there a number of steps that is good? mine are way up there, around 65.
Old Oct 11, 2009 | 11:13 PM
  #72
Jack_of_Trades's Avatar
Does anyone know a way to activate Evoscan's SAS Mode to adjust the BISS while being able to still log RPM??? My mirage's tach sucks below 1000 rpm so I have no idea what RPM I'm actually setting the BISS for
Old Oct 12, 2009 | 12:05 AM
  #73
Evo_Jay's Avatar
And this thread was started before V7 came out.
Old Oct 12, 2009 | 12:17 AM
  #74
Evo_Jay's Avatar
Also do we have the
Do we have these table for any of those ROMS?? Since the ROMs listed above are ones WITHOUT the throttle hang, I wanna see what those tables are on them and compare to ROMs with the throttle hang.
I think a complete fix may be this.....
Making all the follow tables on 9653 the same as 9417
-all Decel Fuel Cut Delay tables
-the Idle stepper look up table
-ISCV Demand RPM Adder
Also, I think the "Decel Fuel Cut Delay Retard" should stay STOCK. I think retarding timing during throttle lift-off is a good thing.
Oh another side note, I will be switching to 9653 in the next couple days and then Ill be able to work more and test more on finding a fix.
Old Oct 12, 2009 | 12:21 AM
  #75
Evo_Jay's Avatar
This issue is actually on ALL 05+ ROMS. So its not just a 9653 only problem, its an all ROMs 05 and up problem..
Also it defiantly has nothing to do with V7.
