TephraMod V7
Old Jul 31, 2012 | 06:29 AM
  #2686
rsvRob's Avatar
Not sure I can see those tables, will check later when I get the laptop.
I did notice the injector latencies were different between roms...
What about swapping to 88580714?
ISCV idle tables
Old Aug 11, 2012 | 03:24 AM
  #2687
hilaloruc's Avatar
Do you have a Patch For MAF sensor, I wanna delete the MAF... (Just Trying to tune with MAP)
Old Aug 11, 2012 | 08:01 AM
  #2688
LeveeciusEVOIX's Avatar
The very first page has an evo 8 SD tune (which is what you're looking for to run without the MAF). Read the 2nd post of the topic, and under roms for the evo8, look at option 5, that should be the perfect one for you.
Old Aug 13, 2012 | 02:04 AM
  #2689
stunt2's Avatar
hey guys, have few questions about NLTS
can anyone explain the functions of NLTS load and speed thresholds ?
why they say speed/load must be UNDER this values to activate nlts. and there are 30/150 in these tables accordingly
shouldn't there be stated 'ABOVE' in these tables or I have some faulty defination file ? using 96530706
Old Aug 13, 2012 | 04:42 AM
  #2690
wizzo 8's Avatar
Yes those definitions are reversed for some reason
Old Aug 13, 2012 | 05:41 AM
  #2691
Raptord's Avatar
Yes it's suposed to say "above", not "under" I changed it in my own xml.
Old Aug 17, 2012 | 06:55 PM
  #2692
Moore Auto's Avatar
Is there any way to change the inherit rom? I've had this happen a couple times where I'll tune an Evo on Tephra, then when I go back to open the rom later and the Tephra options are no long there and it's inherit rom is the evobase rom and not Tephra. It doesn't happen all the time, so I'm not sure what's going on. Anyone else have this happen?
Thanks!
~Chris@MooreAutomotive
Old Aug 18, 2012 | 12:14 AM
  #2693
07EvoIX's Avatar
just change the inherit code in the XML for that ROM
cheers
Old Aug 18, 2012 | 07:52 PM
  #2694
ReaperX's Avatar
Question about flashing Tephra roms....
I have seen on some posts that some versions of ECUflash cause problems with flashing these roms. I have been using Evoscan v2.8 to flash my current rom. Will there be any problems in flashing a Tephra rom with Evoscan?
Thank you!
Old Aug 18, 2012 | 08:20 PM
  #2695
07EvoIX's Avatar
iv used many versions of ECUFlash and EvoScan and never had an issue flashing Tephra roms. I think most issues are either car or cable related.
cheers
Old Aug 18, 2012 | 08:23 PM
  #2696
ReaperX's Avatar
cheers
Thank you very much!
Old Aug 19, 2012 | 01:31 PM
  #2697
Moore Auto's Avatar
cheers
How do you do that? You mean in the definition xml?
Thanks!
Old Aug 19, 2012 | 02:32 PM
  #2698
07EvoIX's Avatar
open the XML in notepad (or similar), about 10ish lines down you will see the <inherit> code. You can adjust the inherit there. type the filename (without '.xml') that you wnat to inherit.
though if you are saying it doesnt happen all the time, i would try reinstall the program.
cheers
Old Aug 20, 2012 | 05:07 PM
  #2699
ReaperX's Avatar
I must say I very much love this rom mod. Car feels smoother and with all the resolution in the big maps it's a lot easier to tune the transitions, especially tip-in.
Thank you to all the EvoM elite, especially Tephra.
Old Aug 20, 2012 | 08:33 PM
  #2700
Evo MR IX Fritz's Avatar
Woot cant wait going v7 this week. thanks for all ur work to help out this community
