TephraMod V7
Old Dec 16, 2009 | 09:12 PM
  #1231
Appauldd's Avatar
Yes, the clutch must be in....to the floor. Maybe you need to adjust the clutch switches. They are just plastic and can get moved pretty easily. Test them with a mutimeter to ensure they are correctly set.
Old Dec 16, 2009 | 09:30 PM
  #1232
3gEclipseTurbo's Avatar
^^^BINGO eclipses dont have clutch switches. So now how do i go about this install the two evo clutch switches? thats weird that on the 0008 rom it worked must not need to push in the clutch for the stationary revlimiter to work on that rom. Is there a patch i could do to eliminate the need for the clutch switches?
Old Dec 16, 2009 | 09:48 PM
  #1233
TJung's Avatar
Bump. Is there any other way to set stationary rev limit without clutch switches ?
Old Dec 17, 2009 | 07:10 AM
  #1234
logic's Avatar
Find a way to supply 12V to pin 43 on an VIII ECU, or pin 88 on an IX ECU.
See this thread: https://www.evolutionm.net/forums/ec...ething-me.html.
Old Dec 17, 2009 | 09:44 AM
  #1235
TJung's Avatar
Thx
Old Dec 17, 2009 | 11:23 AM
  #1236
Theres noway to just put in a patch?
Old Dec 17, 2009 | 11:41 AM
  #1237
D-VO's Avatar
Wait a minute...there's not even one clutch swtich? Now that really doesn't make any sense. How did the launch control work before?
Old Dec 17, 2009 | 11:46 AM
  #1238
its just a stationary rev limiter which is active when the car is stopped has nothing to do with the clutch in the 0008 an 0015 roms from what i can tell as they both work on 3g eclise which dont have the clutch switches.
There has to be a patch, im praying right now. Its on my christmas list too.
Old Dec 17, 2009 | 12:57 PM
  #1239
liyellowevo8's Avatar
Hey Im having trouble with getting v7 to work I keep trying to copy and paste the xml files like it says but it hasn't been working, any help much appreciated just pm me.
Old Dec 17, 2009 | 02:10 PM
  #1240
Evo_Jay's Avatar
Pm me and ill help ya.
Old Dec 17, 2009 | 09:44 PM
  #1241
bump for a patch for the clutch switches
Old Dec 18, 2009 | 01:35 AM
  #1242
fostytou's Avatar
EvoM Community Team
For the eclipse guys with the stationary rev limiter problem.... make sure you are waiting long enough to check operation. You have to be going slower than a certain speed for a certain period of time for it to kick in. Check speed sensor operation also. It couldn't hurt to set the limiter lower to something like 3k RPM to test.
Old Dec 18, 2009 | 02:10 AM
  #1243
ive tryed everywhere from 2k-5.5k nothing and completely stopped for maybe 20min. Its because of the clutch switches which we dont have. We need a patch from the Ecu God....tephra... PLEASE
Old Dec 18, 2009 | 12:13 PM
  #1244
logic's Avatar
Originally Posted by TJung
Thx
I just noticed you're in Poland; those pinouts are for USDM models, so just as a friendly warning, you'll want to verify your pinout before diving in head-first.
Old Dec 18, 2009 | 11:03 PM
  #1245
rdtech's Avatar
been having problem to get the idle to run right. I've been testing 96530706 for a awhile now and have tried to look at it again today. I'm having a bit of issue with idle on an evo 8. Idle by itself is fine but when I drive and come to a stop, it dips all the way down to the point where its gonna die then comes back up. Its weird. I flashed the v5.10 (96420011) map and its fine again.
Phenem - have you encountered this. Am I over looking something. I've checked the idle tables and transferred the map from v5.10 over to .7
Logic, Tephra, JO, fostyTou - any idea whats going one here?
