need help guys!!
Old Oct 18, 2009 | 12:01 PM
GottaZtt's Avatar
need help guys!!
Greetings to all,
I recently moved to the middle east and i have been tuning cars for a while, and not much stock ecu's. so now i have an evo 7 and 9 that i am try to get into and its just not working
i get codes like 00001 000002 ffffffffff
and dont have no firewall
i fo14.1 software and still no luck with openport 2.0
i have the vin number of the vehicle i am working on if it can help in anyway
jmysnct9a1u000357
this is one of the vins.
all the help i can get would help
Old Oct 18, 2009 | 02:02 PM
todd6027's Avatar
try this open the unlocker leave it running then use ecuflash
http://www.aktivematrix.com/forum/dl...ile&file_id=13
Old Oct 18, 2009 | 03:24 PM
GottaZtt's Avatar
^thanks, i hope this works!
Old Oct 18, 2009 | 05:18 PM
tephra's Avatar
try and make your posts more coherent
You will get more help!
Old Oct 19, 2009 | 01:24 PM
GottaZtt's Avatar
after downloading the EcuFlash Unlocker, starting it before starting EcuFlash and the result was the same:
[23:16:54.871] EcuFlash Version 1.41.2483
[23:16:54.871] OS Version Windows XP
[23:16:54.871] Qt Version 4.4.0
[23:16:54.871] 26 memory models read.
[23:16:54.871] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[23:16:55.012] 342 ROM metadata models scanned.
[23:16:55.012] checksum module "subarudbw" loaded.
[23:16:55.012] checksum module "mitsucan" loaded.
[23:16:55.012] flashing tool "wrx02" loaded.
[23:16:55.012] flashing tool "wrx04" loaded.
[23:16:55.012] flashing tool "sti04" loaded.
[23:16:55.012] flashing tool "sti05" loaded.
[23:16:55.012] flashing tool "mitsukernel" loaded.
[23:16:55.012] flashing tool "mitsukernelocp" loaded.
[23:16:55.012] flashing tool "mitsubootloader" loaded.
[23:16:55.012] flashing tool "shbootmode" loaded.
[23:16:55.012] flashing tool "shaudmode" loaded.
[23:16:55.012] flashing tool "subarucan" loaded.
[23:16:55.012] flashing tool "mitsucan" loaded.
[23:17:05.324] J2534 API Version: 04.04
[23:17:05.324] J2534 DLL Version: 0.50.2464 Jan 29 2009 10:58:58
[23:17:05.324] Device Firmware Version: 1.07.2597
[23:17:07.356] sending init sequence 1 (0001)
[23:17:10.621] sending init sequence 1 (0003)
[23:17:13.903] sending init sequence 1 (FFFF)
[23:17:17.184] sending init sequence 1 (F0F0)
[23:17:19.903] no response to any known code
[23:17:19.903] interface close
one of my other friends have version 1.3xxxxxxx and it worked and get into the ECU, but when we tried to view the maps none could be selected. all was hidden.
Old Oct 19, 2009 | 02:37 PM
todd6027's Avatar
your cable problem then maybe , does he have the proper definition for that rom
Old Oct 20, 2009 | 06:04 AM
GottaZtt's Avatar
does anyone have ecuFlash 1.3xxx
Old Oct 20, 2009 | 07:35 AM
rolly1818's Avatar
Registered User
search on google someone posted it. or PM me i MAY have it
Old Oct 20, 2009 | 03:13 PM
todd6027's Avatar
http://openecu.org/index.php?title=EcuFlash
@GottaZtt e mail sent
Old Oct 26, 2009 | 03:54 PM
GottaZtt's Avatar
it feels like i am running in circles with this EcuFlash software.
I recently was sent a ecuflash v1.34
and having installed OP2.0
i run the software and it does not allow me to click on READ ECU
on the same window of ecuflash bottom right corner it says openport 2.0 com 11
I recall when i use standalones the com was a problem i dont know if this is a factor or not just throwing it out there.
Old Oct 26, 2009 | 04:11 PM
todd6027's Avatar
dont think op2 works with v1.34 not sure
Old Oct 26, 2009 | 04:30 PM
tephra's Avatar
a) I'm not sure OP20 will work with EcuFlash 1.34
b) I'm not sure the ECU Unlocker will work with the OP2.0
get your friend to read the ecu for you, then change the init code back to 0x0001
Then your OP20 with EcuFlash 1.42 will work
Deano_Engineer_
Nov 7, 2016 04:31 PM
BigBlockDaddy
Aug 17, 2015 11:43 PM
Jhusey
Jun 14, 2013 10:02 AM
mcthar
Jun 1, 2012 01:25 PM
wiretap
Apr 15, 2005 04:22 AM
