new live map app
Old Oct 13, 2011 | 06:16 PM
  #331
ziad's Avatar
if u game ... first the bad news, i am not 100% sure if it will work on ur car. on another evo9 it works fine.. but on my 8mr with a 9 ecu, i was having idle issues. so maybe my car.
anyway to summarise, think of it as mut3 on steroids. very high logging speeds 500-1000 items/sec with normal baud rate of 15625), plus ability to read/write some tables on the fly (in ram). in the same program/screen u have a realtime as well as an offline map tracer, graphing and even VDR (though it does not display same numbers as VD) plus currently the ALT Ignition, fuel, WGDC, BDEL and injector scaling maps can be edited in ram.
you can change the order of items being displayed etc without issues, and i find no artifacts when logging 2 byte items. and best of all it (the program) can convert your non dma/livemap rom to a dma rom. with plans to do the otherway around incase ppl want to revert back to a normal rom.
the output is a CSV file... and obviously is different from evoscan. to get the data from the app in real time while its running...... might be hard to do... but send me a pm we can discuss.
what cant it do..... make u a better driver or a better tuner (i know cuz i fail at both)
Old Oct 17, 2011 | 07:55 PM
  #332
markyang83's Avatar
Hi Ziad
I would really want to try your live map tunning program, however your download link seems like not working, will you be able to pm me the program please.
Cheers
mark
Old Oct 18, 2011 | 12:14 PM
  #333
ziad's Avatar
mark what rom are u using or planning to use.... currently only AUDM evo9 is. with USDM evo9 in early beta.
Old Oct 18, 2011 | 12:32 PM
  #334
nocabiwiksmx's Avatar
Originally Posted by markyang83
Hi Ziad
Cheers
mark
Im after the same thanks Ziad
Old Oct 18, 2011 | 03:44 PM
  #335
ziad's Avatar
its just as easy as sending me a pm with ur email address and evo model (rom id)
Old Oct 19, 2011 | 02:04 AM
  #336
markyang83's Avatar
Hi ziad
I'm using jam evo9, the rom ID is 88570008.
Cheers
Mark
Old Oct 20, 2011 | 07:01 PM
  #337
Monochrome's Avatar
I would love to try this program in my 3000GT VR4! Ziad, can you adapt it if I sent you a definition file? It's a 16bit H8/500 based ROM.
Old Jan 3, 2012 | 04:48 PM
  #338
ziad's Avatar
hey guys new version uploaded and available. its more of the same. just fixing bugs. VDR is working. patching all V7 roms is done. XMLs were re-done to match Donner's xmls.
but most importantly i did some documentation to give ppl an idea what this program is all about and how to use it. its early early documentation, and would love some more help to "fix" it up.
good luck
Old Jan 3, 2012 | 05:02 PM
  #339
Raptord's Avatar
good luck
Does "all v7 roms" include 88590715? (USDM Evo IX)
EDIT: Answered my own question while reading the new documentation. Thanks Ziad! Will definitely donate once I get this working for my car!
Old Jan 3, 2012 | 05:25 PM
  #340
ziad's Avatar
my pleasure
donner is going to start working on 9471 soon... so maybe all is slightly not true
Old Jan 3, 2012 | 10:23 PM
  #341
donner's Avatar
Thanks to ziad for adding VE map livetracer, makes VE tuning easier!
See supported roms: www.petterimutteri.fi, 2=live and 6=sd2.0+live (also VE map is livetunable). All roms are tested but as usual, be careful wih this stuff Some rom packages are password protected due to tephra donation-only (9055 and 9626), contact him if you need 9055 or 9626 versions.
Old Jan 5, 2012 | 02:33 PM
  #342
burgers22's Avatar
Nice work guys. Hopefully I'll get the car back soon and get this running.
Old Jan 10, 2012 | 07:34 PM
  #343
gear head's Avatar
nice update
Old Jan 11, 2012 | 11:50 PM
  #344
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
my pleasure
I have sent XML definition parser and OP20 "how to" to ziad
so hopefully we can enjoy both things soon :P
Old Jan 12, 2012 | 12:01 AM
  #345
donner's Avatar
You mean OP2.0 DMA support? Great!
By the way, is DMA supported in older H8 processors?
