new live map app
Old Apr 6, 2012 | 06:34 AM
  #481
ziad's Avatar
guys i havent made it live yet... but if someone is looking at this thread and wants to test the new version please let me know. the link is here.
(REMOVED by ziad)
to get the LC1/ZT2 working, u need to goto requests tab in settings, choose the logger there and the correct com port. also note that a request needs to be there for the WB to work, u can create a dummy request, just make sure in data defination WB is pointing to that. otherwise it will not work or overwrite the current WB item.
CAR PC mode is working too, i hope, remember that once u enable it best to restart the program, as sometimes it does not update the screen properly.
this is definately a test version, i havent been able to do test runs on it. let me know via email if there are any problems. if a few ppl test it i will update the doco and put it up properly.
Old Apr 11, 2012 | 02:43 PM
  #482
ziad's Avatar
ohh ohh i made a facebook group for ELM. do a search for "EvoLiveMap" hopefully will get a few ppl joining up, haha
version 0.5 will be up by the end of the week, doing some documentation currently.
Old Apr 12, 2012 | 11:22 AM
  #483
And's Avatar
And
sorry not been able to test yet as my battery is dead completely (reading 8V) so just waiting for a new one to turn up so I can use the car again hopefully tomorrow and can test
Andy
Old Apr 14, 2012 | 02:46 AM
  #484
And's Avatar
And
I managed to get round to testing, the carpc mode works a treat and the large tabs are ideal , the read maps on start up works too, although I still get the index 0 error when I select the SD option and it crashes ELM .
With the larger request screen can you double the size that you've currently got? as that would fill the screen just right, also none of the boxes got up dated when logged but I guessed that wasn't finished yet
thanks for all the work on this
Andy
Old Apr 18, 2012 | 05:16 AM
  #485
ziad's Avatar
0501 is up guys, just fixed a few small bugs from 0500, and has auto update feature. so when new version is released it can download the patch and apply it. saving ppl having to download the new installer and installing it.
major updates should still happen via the installer.
now not just you get faster logging you can get faster upgrades too
EDIT: actually i am upto 0502 now
Old Jun 10, 2012 | 03:43 PM
  #486
ziad's Avatar
its still 0502....but anyway just bumping thread as i posted a short video on how to patch a rom to use EvoLiveMap. also shows how good the map tracer looks, as well as a quick look of the interface.
also a quick update i got some big plans for the program. initially i am planning on increasing the maps available. currently we have:
ram mut table, timing, fuel, injector scaling, boost load and boost wastegate duty cycle.
in the next version i plan to add:
injector latency, maf scaling and for evo9 people mivec table
and some more tweeks happening too.
Old Jun 10, 2012 | 03:49 PM
  #487
Dynotech Tuning's Avatar
I will definitely give it a try soon. So helpful for idle stuff!
-Jamie
Old Jun 10, 2012 | 04:39 PM
  #488
ziad's Avatar
that be awesome jamie. if u need anything let me know
Old Jun 12, 2012 | 10:12 AM
  #489
And's Avatar
And
i'm still using it, although not used the car for a month as been working in the Atacama desert and now I've stripped the manifolds off to port and fit a S214B turbo and s90 throttle body
Old Jun 13, 2012 | 07:25 AM
  #490
ziad's Avatar
ok got some time and did some work on the program. i need someone running the following two roms, who could test maf scaling and injector latency tables. once this is tested i will move to evo9s and move these two as well as mivec tables.
90550001
96530006
Old Jun 13, 2012 | 07:34 AM
  #491
Raptord's Avatar
looking forward to that!
Old Jun 13, 2012 | 09:36 AM
  #492
Nsk's Avatar
Nsk
90550001
96530006
I'm using the 90550001 and would like to help you.
Old Jun 13, 2012 | 08:09 PM
  #493
ziad's Avatar
send me an email with ur current rom i will patch it and send u instructions for ELM.
my address is livemap at mztec dot org
Old Jun 14, 2012 | 10:48 PM
  #494
dingus's Avatar
Still Here...
I am still around and working with the 88592715 rom. After the upgrade to v5 I lost my data logging settings and am in the process of setting this back up. While setting it up I was having trouble seeing the entire RAM MUT table in ECUFlash. I made changes to the ECUFlash XML (TephraMOD-88592715-v7.xml), basically copied how the MUT table is setup in tephra by using the 'RamAdress' scaling, to not display the leading 'FFFF'. Anyone who wants to use this will probably have to change the addresses and maybe only have on row (I expanded my RAM MUT to 32 requests to there is an extra row).
Code:
    <table name="RAM MUT Table @ FFFFA230" category="DMA" address="4a280" type="3D" level="1" scaling="RamAdress">
        <table name="X" type="Static X Axis" elements="16">
            <data>0</data>
            <data>1</data>
            <data>2</data>
            <data>3</data>
            <data>4</data>
            <data>5</data>
            <data>6</data>
            <data>7</data>
            <data>8</data>
            <data>9</data>
            <data>A</data>
            <data>B</data>
            <data>C</data>
            <data>D</data>
            <data>E</data>
            <data>F</data>
        </table>
        <table name="Y" type="Static Y Axis" elements="2">
            <data>0</data>
            <data>1</data>
        </table>
    </table>
IDK...I found it useful since I have a wee little netbook for tuning...
Old Jun 18, 2012 | 02:52 PM
  #495
ziad's Avatar
awesome work dingus. evo9 mivec move i will look into this week... depending on work... its been very busy with server crash etc. and the mivec maps cause other issues where i have to move a lot of oter stuff to get it to work.... but hopefully will be ready for beta testers. if people want to send me 8859 and 8858 roms, please do so. u know my email, or send me a pm.
