Map interpolation using a flex fuel composition sensor?
Old Oct 24, 2009 | 12:34 PM
SoCal Rally's Avatar
Lightbulb Map interpolation using a flex fuel composition sensor?
In a previous thread regarding E85 and the alt-map switching harness, mrfred wrote:
Originally Posted by mrfred
It works great with the factory ECU, and its only going to get better. I found a spare ADC (0-5V signal) input on the factory ECU. A toggle switch is wired up so that this input sees either 0 V or 5 V. tephra has recoded the ECU so that the ECU will choose between two sets of maps depending on which voltage it reads at the this ADC input. The maps right now include timing, fuel, boost, and I believe injector scaling. We may expand this range of maps, and for sure we will eventually setup interpolation between the two maps based on input voltage so that a flex fuel composition sensor can be wired up the ECU to make the Evo a true flex fuel vehicle.
Any idea if it is still planned to implement this feature?
Especially with the variation in ethanol content in the E85 available from E85 pumps, and with people switching back and forth between 91 & E85 leading to different composition mixes of 91 & E85, this feature would be pretty useful. Plus it would obviate the need to switch backwards and forwards between maps, accidentally running the wrong map etc.
Old Oct 24, 2009 | 05:29 PM
fostytou's Avatar
EvoM Community Team
His mapping of the fuel routines was an initial step. Why create a new thread insted of bumping the old one?
Old Oct 25, 2009 | 02:10 AM
Not sure what / which thread you are referring to here.
Why create a new thread instead of bumping the old one?
'mrfred' post I quoted was taken out of a thread that is about 6 months old, and seemed more related to general E85 tuning rather than the specific question I am asking.
Old Oct 25, 2009 | 09:13 AM
fostytou's Avatar
EvoM Community Team
https://www.evolutionm.net/forums/ec...l-options.html
old but on-topic: https://www.evolutionm.net/forums/al...ming-soon.html
Old Oct 26, 2009 | 05:36 AM
mrfred's Avatar
Now that v7 is done and have a stable base code layout to work from, I can begin work on the patch.
Old Oct 26, 2009 | 07:36 AM
Excellent. Thanks!!
ast
Aug 19, 2025 07:09 PM
dudical26
Jan 10, 2020 08:21 AM
tephra
Aug 20, 2019 03:56 AM
mrfred
Jun 26, 2015 07:29 AM
mrfred
E85 / Ethanol
40
May 20, 2012 01:22 PM
