help me with my evoscan error
Old Dec 1, 2009 | 03:27 AM
mike86's Avatar
Hey Guys/Girls,
I've searched and searched but still can't find any solutions to my problem.
i have tried both mistulogger and evoscan and both seem to have the same problem occurring. I am able to connect to the scanner when my engine is off and it will stay connected fine. As soon as i turn the engine on it will either work for about 3 seconds then disconnect or just disconnect straight away. I have also tried connecting to evoscan with the engine already running but this doesn't help either.
When evoscan has disconnected once it looses the ability to find the tactrix 1.3u cable. The solution has been to swap to a different com port but this hasn't helped the disconnecting issue. below is the error that is given when it disconnects.
Info: Initialize Vehicle ECU...
Info: Initializing At 5 baud...
Info: Initialization Complete...
Info: Waiting for INIT Response...
Info: ECU ID: E4B5
Info: Connection successful...
Error: ML Write command error. (FT_Status: 4)
at #=qcYTi9Xx62Q46MlRsGjuPN1obrQTs8A5PdOAFjpb$dxs=.#= qWI1iCxyK3S3lwUZt78q$wA==(String #=qfYtdU1te8HdvgUixlJO_HQ==)
at #=qcYTi9Xx62Q46MlRsGjuPN1obrQTs8A5PdOAFjpb$dxs=.#= qI2Bxs8jh5r0BxamKtYJJTA==()
Info: Datalogger Ended.
There was another error too which was FDTI error 4.
How do i fix this problem. I'm really keen on logging but i'm getting turned off by the unreliability of evoscan.
Old Dec 1, 2009 | 03:31 AM
Evostacio's Avatar
I had this same
problem but the reason was cause a newer version came out and that old one didn't work. Do u have version 2.6. If not u might have to download the newest one or uninstall and then install again. That's all I got man
Old Dec 1, 2009 | 12:07 PM
Evo_Jay's Avatar
Originally Posted by mike86
Hey Guys/Girls,
Info: ECU ID: E4B5
First off, I have been using EvoScan for MULTI yeah (since it came out) and I have never had any connection/logging problems.
Next, can you use ECUflash? If so, try uninstall Evoscan (make sure delete the Evoscan folder and to restart your computer after uninstall), then reinstall Evoscan.
If you cant use ECUflash, uninstall everything (evoscan, ecuflash and the tactrix drivers), make sure to delete all the pertaining folders and instances of those programs/drivers. Restart, then reinstall ECUflash. then plug in cable and install the drivers. then check to see if ECUflsah and the cable drivers are working. If so, then proceed to install evoscan.
Old Dec 2, 2009 | 03:09 AM
mike86's Avatar
I have tried all of this but nothing changes. Whats interesting is that i am able to read the ECU on one laptop but unable to see the parameters oh the other when using ecuflash. Even when i add the same XML file to each rommett data file. WTF
I'm getting ready to burn this cable. Is the 2.0 any better?
Old Dec 2, 2009 | 06:11 PM
Evo_Jay's Avatar
Have you went to the evoscan website and submitted a support ticket?? Hamish is really helpful and responds in a timely manner.
and NO the 2.0 isnt better, if you have an Evo 7-9
and you have .xml problem with ecuflash, probably from you messing with stuff.
Uninstall and delete everything, clean registry, restart and reinstall everything.
Old Dec 2, 2009 | 09:48 PM
mike86's Avatar
I've sent him 2 support tickets and even an email to his hotmail account but havent heard anything for a week. maybe he's away on holidays or something. I guess i'll be patient... what else can i do
Old Dec 3, 2009 | 08:42 AM
rdtech's Avatar
This is what I would do. It works for me as well.
Old Jan 19, 2010 | 07:22 PM
project95gsx's Avatar
Any update to this? I'm getting the same error.
Old Jan 19, 2010 | 07:47 PM
Drill_Sergeant's Avatar
Veteran: Army
what version of evoscan are you using? have you tried v2.5?
v2.5 seems to be the best version for me.
are you using some sort of wideband o2 sensor?
for a few days i had problems trying to log if i was connected to my wideband
have you tried revo uninstaller?
google that and try it out. i was having all sorts of problems with just about every version of evoscan acting up when connected to my AEM UEGO. finally i downloaded revo and used it to completely wipe evoscan from my computer. I reinstalled evoscan v2.5 and everything works flawlessly to include the AEM UEGO.
Old Jan 20, 2010 | 11:49 AM
Woah - sweet dude, thanks for all the info. Yes, I am trying to use my UEGO too, but I'm not sure if I have always had it connected. Right now I'm trying Mitsulogger to see if I can isolate the issue to evoscan. I'll probably go back to 2.5 (using 2.6 currently if it IS an evoscan problem). I'll let you know what happens - Thanks again for your input!
Old Jan 20, 2010 | 07:04 PM
Veteran: Army
v2.6 definitely will not work with UEGO. i think there are a few rare cases of it working.
a lot of people have had success with v2.7 beta 5 upgrade, however i did not.
but yes, try to log without the UEGO hooked up and see if it'll atleast log without it.
Bewstzalot
Jul 7, 2017 01:35 PM
Inprogress
Dec 22, 2015 04:25 AM
fabiangt79
May 8, 2012 12:15 PM
Go_Lancer_Go
Jan 4, 2010 09:18 PM
Evo_Matt
Mar 18, 2008 04:36 AM
