looking at ignition retard limit control, need some logging assistance
Old Dec 10, 2009 | 08:19 AM
mrfred's Avatar
Originally Posted by scheides
Turns out I only had -20's in half of my map so timing was bouncing around. Set top half of map to -20's and re-ran (I called this value you're looking for RevLimContVar:
side note: is this high knock count normal?
Thanks for the log. Not sure about the knock count. I assumed that since there was so much interest in the launch maps, that a lot of people were routinely setting up this pseudo-antilag. If this isn't something you normally do, then don't continue on my behalf.
Old Dec 10, 2009 | 08:22 AM
scheides's Avatar
EvoM Moderator
well its -3°F here now and snow tires are on, but I'll be using it soon enough
Old Dec 10, 2009 | 01:19 PM
scheides's Avatar
EvoM Moderator
I'm bumping my retard limit (173e) to 255 w/ info from that other thread, but from what I read that doesn't affect anything? I'm going to log it and see what happens anyways, just to verify.
Also, saw that just stomping on the gas to hit this rev limiter will cause lots of knock, thus my mountains of it above, we'll see if that goes away too w/ proper technique
Old Dec 10, 2009 | 11:32 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Originally Posted by mrfred
After looking over the timing limit subroutine a little more last night, I'm beginning to think that those tables are not so valuable. Ultimately, that limit of #203 needs to be increased to #231 to allow -20 deg. People are reporting momentarily reaching -20 deg and then tapering down to around -15 to -10 deg. There is something going on that's pulling r2 down from 231. It must be that bit of math and comparison that takes place after constraining r2 to the limit value.
BTW, you saw that the final RAM value at the end of the subroutine only serves to monitor timing via MUT and OBD? Its the second-to-last RAM value that appears to be the timing value used by the ECU.
Now I am confused a little if we are speaking about sub 29754
then I have named it ADJUST_IGNITION_BY_KNOCK_SUM
and there is not much going on, I was speaking about the
sub 1B4AC where the tables are and FFFF6DBC which seems RPM based knock ignition trim with lookup at 1CC2C.
Old Dec 11, 2009 | 11:24 AM
scheides's Avatar
EvoM Moderator
I upped 173e to 255 and saw a blip of -14°. I need to flatten out the launch fueling map as my afr is all over the place still. I'll try and get a better log sometime. Also have your variable still logged in there mrfred, stays 195 constant.
EvilEvolution8
Apr 10, 2024 08:45 PM
SnailSpeed
Dec 13, 2015 04:31 PM
mrfred
Jun 26, 2015 07:29 AM
mrfred
Dec 11, 2011 06:01 PM
Ksyrium11
Jun 11, 2007 06:09 AM
