bad scaling definition for max downward WGDCC
Old Jan 2, 2010 | 02:50 PM
mrfred's Avatar
Hey Folks,
Just found out that the scaling definition that I used for the Max Downward WGDCC table is incorrect. Using the stock value is modified using the incorrect scaling large positive WGDCC values may result. Find the "OffsetWGDC" scaling in your evo9base.xml or evo7base.xml file and replace it with:
Code:
<scaling name="OffsetWGDC" units="%WGDC Change" toexpr="(x-128)/2" frexpr="x*2+128" format="%.1f" min="-64" max="63.5" inc="0.1" storagetype="uint16" endian="big"/>
Old Jan 2, 2010 | 03:32 PM
black E's Avatar
so what is that table used for?
Old Jan 2, 2010 | 03:49 PM
nonschlont's Avatar
I replaced this scaling for the old one, and it scewed the upward correction table. The downward tables was still @ -64%
Old Jan 2, 2010 | 06:50 PM
SoCalRedLine's Avatar
good find!
Old Jan 2, 2010 | 07:19 PM
Appauldd's Avatar
Originally Posted by nonschlont
i replaced this scaling for the old one, and it scewed the upward correction table. The downward tables was still @ -64%
^..+1
Old Jan 2, 2010 | 08:10 PM
mrfred's Avatar
Crap. You're right. Now its getting more complicated. Two separate scalings are needed for the Max Upward and Max Downward correction tables. Use the OffsetWGDC-8 for the Max Upward correction, and use OffsetWGDC-16 for the Max Downward correction.
Code:
<scaling name="OffsetWGDC-8" units="%WGDC Change" toexpr="(x-128)/2" frexpr="x*2+128" format="%.1f" min="-64" max="63.5" inc="0.1" storagetype="uint8" endian="big"/>
<scaling name="OffsetWGDC-16" units="%WGDC Change" toexpr="(x-128)/2" frexpr="x*2+128" format="%.1f" min="-64" max="63.5" inc="0.1" storagetype="uint16" endian="big"/>
Old Jan 2, 2010 | 08:29 PM
mrfred's Avatar
Originally Posted by razorlab
Wow you are quick.
- Bryan
This is a nasty one, so I figure I should fix it ASAP.
Old Jan 2, 2010 | 08:37 PM
Appauldd's Avatar
We will need to keep the original Offset WGDC scaling too. If we change it...the Boost Error Correction table and MAF IAT WGDC table get messed up.
Oh what a can of worms this became.
Old Jan 2, 2010 | 08:41 PM
Appauldd's Avatar
My v7 is missing the Max Downward table....someone please post the XML ? ?
Old Jan 4, 2010 | 11:52 AM
fostytou's Avatar
EvoM Community Team
for 88590015:
Code:
  <table name="Max Total Upward WGDC Correction vs TPS" category="Turbo Boost Single Solenoid" type="2D" scaling="OffsetWGDC-8">
    <table name="TPS" type="Y Axis" elements="9" scaling="ThrottlePercentage"/>
  </table>
  <table name="Max Total Downward WGDC Correction" category="Turbo Boost Single Solenoid" type="1D" level="3" scaling="OffsetWGDC-16"/>
  <table name="Max Total Upward WGDC Correction vs TPS" address="3f10">
    <table name="TPS" address="7284"/>
  </table>
  <table name="Max Total Downward WGDC Correction" address="1658"/>
Old Jan 4, 2010 | 06:51 PM
Appauldd's Avatar
Cool beans.....now if I could just get the addresses for v7 9653.
Old Jan 4, 2010 | 07:32 PM
logic's Avatar
9653:
PHP Code:
<table name="Max Total Upward WGDC Correction vs TPS" address="448a" category="Turbo Boost Single Solenoid" type="2D" scaling="OffsetWGDC-8">
    <table name="TPS" address="6c2a" type="Y Axis" elements="9" scaling="ThrottlePercentage"/>
</table>
<table name="Max Total Downward WGDC Correction" address="1a58" category="Turbo Boost Single Solenoid" type="1D" level="3" scaling="OffsetWGDC-16"/>
Old Jan 4, 2010 | 08:42 PM
Appauldd's Avatar
Ed....you are missing a / before the > on the Downward table.
Old Jan 5, 2010 | 06:58 AM
logic's Avatar
Good catch. Fixed.
Old Jan 5, 2010 | 08:35 AM
Danieln's Avatar
Can you please post also the tables for 88570008 please.....
Much appreciated....
