Launch Control WTF?
Old Jan 14, 2010 | 04:50 PM
biggie5252's Avatar
Launch Control WTF?
I decided to mess around with launch control maps (tephra v7) and took some logs. Here's what I came up with.
Everything seems to jump around so much and of course the super high knock numbers. This is on E85. Any insight and advice would be appreciated. Thanks.
Old Jan 14, 2010 | 05:10 PM
hediki12's Avatar
interesting try easing up off the throttle so that its a little (10% ?) past the poit were it activates the 2step... also i honestly dont think its practical in "violent" situation like this that actual afr will match map.. try dropping map afr to 8s-7s. and see ..
Old Jan 15, 2010 | 01:21 PM
fostytou's Avatar
EvoM Community Team
Violent things are happening, violent reactions occur. There is plenty of data on this on the forums.
If nothing is hitting and you are still knocking really hard, try easing into the throttle rather than just mashing it. That usually takes care of that problem for most people.
Old Jan 15, 2010 | 02:40 PM
biggie5252's Avatar
I did ease into it. It actually took me 5-10 seconds to get from idle to full throttle. Unless that is too fast. I did some quick searching, but didn't come up with much. I'll look a little deeper.
I know I'm not supposed to get a smooth log, but I didn't think it would be so extreme.
Old Jan 15, 2010 | 02:43 PM
hediki12's Avatar
just do do 100% throttle
Old Jan 15, 2010 | 02:46 PM
hediki12's Avatar
try this link https://www.evolutionm.net/forums/ec...unch-maps.html
Old Jan 15, 2010 | 02:54 PM
biggie5252's Avatar
Thanks. I'll play around with it more and see what I come up with.
Old Jan 15, 2010 | 09:27 PM
tephra's Avatar
dont worry about logging 2byte rpm...
1byte is heaps good enough
Old Jan 16, 2010 | 08:36 AM
biggie5252's Avatar
Yeah, I know. I need to change that offset number in Evoscan, but it won't let me edit data list items from Evoscan. I just haven't done it in the xml yet.
Old Jan 16, 2010 | 10:04 AM
LV///R's Avatar
I'm having the same issues. Lots of knock with my launch control. I'm also running E85. I'm going to try "easing into it" to see if that helps, because every time I used it last year, I just mashed it (autox).
Old Jan 18, 2010 | 09:16 AM
4u2nvme's Avatar
Ive never had any knock issues with my launch control
dfarmer0033
May 18, 2017 08:43 AM
hotrod
Feb 11, 2014 10:36 AM
Yoo Shin
Cobb AccessPORT
May 25, 2012 08:39 AM
midwestmonster
22
Nov 17, 2005 06:43 AM
EVOMIZ
AEM EMS
11
Jun 6, 2004 07:36 PM
