E85, 0.015 Plugs gap and still misfiring. Help!? Any tuning expert? Maps inside
Old Jan 29, 2010 | 12:51 PM
  #31
JohnBradley's Avatar
Originally Posted by JDMevoBOOST
Do you have a Sun Hyperforce by chance?
or HKS DLI?
Old Jan 29, 2010 | 01:55 PM
  #32
fostytou's Avatar
EvoM Community Team
Originally Posted by JohnBradley
Looking at the map in detail, the boost cut is disabled. If it were 465 on a dynojet I have seen 490 with the 1000s going static out the top. If the 255 is not modded it will flow less. We need a log or 3 to see exactly whats going on. If we knew where 2 byte load was going that would help. Too many variables at this time to make a 100% accurate decision, however its obvious that some stuff needs addressed. There are some good E85 timing maps up. I posted one awhile ago for a 475whp e85 car on a 57 trim. At 28psi it was knock free and not near MBT. That car was also on 1200s and the IDC were only 83% on the EvoScan scale (it goes to 115% not the normal 80-100%).
Shouldn't MBT change significantly in a 2.3 Stroker?
Old Jan 29, 2010 | 02:15 PM
  #33
JDMevoBOOST's Avatar
My Hyperforce is currently on the fritz and even at a .020 gap I am having some random break up. Just little tugs and millisecond of lost power randomly at full throttle in 3rd and 4th, which is why I ask.
Old Jan 29, 2010 | 02:55 PM
  #34
I wouldnt say significantly but it will change a few degrees. If nothing else my E85 map I referred to was really pretty tame so it can be used a 2.0 ready to go or a good starting point on a 2.2/2.3l
aaron
Old Jan 29, 2010 | 02:58 PM
  #35
fr34k's Avatar
my car is on stock ignition. No hyperforce or HKS DLI.
it was dynoed using dynapack.
I just did a datalog and I am now certain that my car hit fuel cut on those WOT runs.
and as you guys said, I am getting a lot of knock because of the loussy timing maps.
I just sent Aaron at english racing my log file and ROM for him to take a look. Thanks alot btw!
Old Jan 29, 2010 | 03:25 PM
  #36
379.68 2 byte load clip, disable the Load Cut and it should be back to normal. Rescale your map so you are actually on the map as well. Right now you are WAY off the map to the left at peak boost.
Old Jan 29, 2010 | 03:30 PM
  #37
Old Jan 29, 2010 | 03:55 PM
  #38
fr34k's Avatar
Aaron, how do I disable Load Cut? I'm new to tuning with Ecuflash.
another question, so that loadMUT2byte IS the load value on the ROM fuel map and ignition map?
the maps are now only scaled to 300, and should be rescaled?
Thanks
Old Jan 29, 2010 | 05:02 PM
  #39
Drifto's Avatar
Originally Posted by fr34k
Hey guys,
My car was tuned at 27psi for E85. I have 2.3L motor with GT30R turbo.
I am experienceing a huge misfire (felt like i hit a car in front of me) even at only 25psi. Did not have this problem before, even at 27psi.
I felt that the amount of boost i can run before misfiring gets lower and lower.
This happens alomst all the time now during WOT 3rd gear up at about 5000rpm. lower rpms at higher gear. 4500rpm at 4th. This is only approximate.
it is usually fine at 1st and 2nd gear
I am using BR8EIX iridium plugs gapped at .015 now. It was fine with this .015 before. no misfire, but over time, the misfire comes back.
Attached are my fuel map and ignition map.
Please help!! Thanks a bunch!
Anthony
Definately boost cut. I just went through this with my car. Went through all variables with ignition and nothing fixed it. Similar scenarios as you would cause it. Look at injector duty cycle in your logs. I'll bet you will see the IPW drop to zero at the same time the event happens. On my car it ended up lifting the head, blowing a head gasket and damaging a rod bearing after repeated events while trying to track it down. Do not continue to drive it until you alter your Boost cut time delay in your ROM. Raise to a min or better and you will find that your "misfire" is gone.
Old Jan 29, 2010 | 05:04 PM
  #40
The log at 5031rpm (after the shift apparently) shows exactly this, right after it hit 378 load.
Fr34k
Its floating around in this thread-
https://www.evolutionm.net/forums/ec...ng-guys-4.html
Old Feb 5, 2010 | 09:04 AM
  #41
fostytou's Avatar
EvoM Community Team
Hi JohnBradley,
Is this the car/tune you were speaking of? https://www.evolutionm.net/forums/7480198-post18.html
Man, looking through the "post your timing maps" thread is really nostalgic with all those tiny maps
Old Feb 5, 2010 | 11:10 AM
  #42
That would be the one
hoof hearted
38
May 1, 2013 03:15 PM
awdordie
Apr 3, 2013 01:56 PM
LimitedSlip7
Jan 29, 2013 05:31 AM
05blue8
23
Jul 21, 2011 06:26 AM
Arkitek
18
Jun 27, 2010 06:53 AM
