coilpack or something else?
Old Jun 8, 2012 | 09:02 PM
awdordie's Avatar
long story short... or as short as i can while still including all details.
other day on the way to work went to pass a slow truck. in 4th boosted to maybe 10 psi around 4k rpm and motor felt like it was experiencing spark blowout maybe a tad more violent along the lines of boost cut. i thought no big deal i just changed the plugs and prob didnt gap them tight enough. bought a new set last night and gapped them down to around .021 where i had them before when getting the car tuned. ran it through 1st 2nd 3rd and let out in 4th... i only took it to around 5k in each gear except 4th. soon as i hit 4th i let out. no misfire or boost cut feeling issue. few miles down the road a car in front of me turns off so i give it another test this time i was in 3rd and was going to do a full pull. at 2500 went wot and at 4k got the misfire or whatever it is.
things i know it should def not be are plugs (changed and gapped yesterday) plug wires ( changed within the last 5 months dont remember exactly when but i do still have the receipt somewhere), tune done by reputable tuner (see signature) and has been fine up until now car was tuned in april. car is tuned on ecuflash at 26 psi and im running ngk br8es plugs.
im leaning towards a bad coil but dont see why it would do it only in a higher gear like a 3rd gear pull and up but not do it with a 1-2-3 pull. what do you think? coils or is it something else. by the way im throwing no codes.
Old Jan 9, 2013 | 08:43 PM
Insanenoodle's Avatar
Hey did you figure out what was wrong? I'm having similar issues...
Old Jan 9, 2013 | 10:14 PM
jessmanEVO's Avatar
I was experiencing the same thing while getting tuned yesterday. Cut the tune short because of it. Def gonna order new coil packs.
I'm running a sparktech pro cdi
Old Jan 12, 2013 | 06:17 PM
Socal's Avatar
It definitely sounds like its your coil packs. Did you fell it loose power at wot, did you have to let off the gas then floor it again?
Old Mar 29, 2013 | 08:46 PM
detroit pistins's Avatar
Bump...any updates on the issues above? i am kind of experiencing similar symptoms.
Old Apr 3, 2013 | 12:36 PM
mollett89's Avatar
I had the same issues for a long time. What plugs wires are you running? If they are after market then I would get some new oem ones. If that doesn't fix it then it's prob one of the coils. If you have a friend with an Evo switch out wires and coils one at a time to troubleshoot it
Old Apr 3, 2013 | 12:40 PM
mollett89's Avatar
My car got a little better with the oem wires and then I changed the coils. The car has been running great for the last 4-5 years
Old Apr 3, 2013 | 01:56 PM
I swapped my coils and still the same issue. I started a thread with some details below.
Thx
https://www.evolutionm.net/forums/ev...sd-93-oct.html
Tommyfacekicker
70
May 20, 2017 09:56 PM
Kody Mills
10
May 13, 2017 12:52 AM
mrhussain
24
Feb 16, 2017 08:01 AM
D1andonlyantman
Nov 11, 2015 12:53 PM
Raceghost
Oct 10, 2011 04:34 PM
