Going back to 94170015
Old Feb 4, 2010 | 04:00 PM
  #76
mt057's Avatar
My 1byte was off because I did not read the first post well enough...oops.
Old Feb 4, 2010 | 04:05 PM
  #77
Boosted Tuning's Avatar
Also, I looked at the ROM and noticed that 2byte load, 2 byte RPM, etc is NOT setup out of the box. Which means to log 2byte load, RPM or airflow, You will have to add the correct info to the MUT table.
EDIT - Me, appauldd or tephra will updated the ROM so its read to log all 2byte stuff out the box.
Old Feb 4, 2010 | 05:41 PM
  #78
Creamo3's Avatar
Looking for confirmation on whether the SD patch for 94170015 can be applied to this ROM.
Old Feb 4, 2010 | 06:06 PM
  #79
mt057's Avatar
Old Feb 4, 2010 | 06:18 PM
  #80
logic's Avatar
I think you'll find that live mapping, in particular, gets it's hooks into tephra's code enough that it won't "just work" going from v5 to v7 without spending a little bit of time resolving differences.
I seem to recall that SD required some effort to forward-port on 9653 as well. l2r99gst, phenem, or mrfred can probably comment more accurately on that.
Old Feb 4, 2010 | 06:44 PM
  #81
Creamo3's Avatar
Key word is "should"; it appears the latest XML in the V7 thread has the patch applied. I just didn't know if Tephra's mods affected the space previously used for the 9417 SD patch. If I get time and nobody responds w/ a definitive I can test it out on my own.
Old Feb 4, 2010 | 08:19 PM
  #82
Appauldd's Avatar
I have not been told of any SD usage with this rom.
As for those that are having logging issues....I explained earlier that the XML is not complete. We are working to get all of the tables properly defined.
Old Feb 4, 2010 | 11:22 PM
  #83
Jim in Tucson's Avatar
Originally Posted by Appauldd
So does anyone have addresses the following for 94170015 ????
Injector Cranking Enrichment IPW Adder (Main)
This is great news. Much thanks to Tephra and all other contributors! I think I'll be switching back to 9417 just as soon as the IPW Adder table is located.
Is anyone using the V7 9417 with E85? If so, how is your cold starting working out? Any other issues?
I found the IPW table to be one of the most useful upgrades in the 9653 ROM for E85 users.
Old Feb 4, 2010 | 11:33 PM
  #84
Appauldd's Avatar
Who can host the XML file for me ? ? ?
It will not have the ISCV Demand tables or a couple other warmup tables. Other than that is it about as complete as I think it is going to get.
Any takers on being a host to the XML so everyone has the ability to download it ? ? ? ?
Oh and Jim....we have that table now.
Old Feb 5, 2010 | 02:30 AM
  #85
ziad's Avatar
i can if u want... need to sort my website a little but its got live map stuff so happy to.... why not the wiki though????
Old Feb 5, 2010 | 07:43 AM
  #86
Appauldd's Avatar
OP Updated.
Thanks ziad....but I just stuck it in the wiki.
I posted the rom and xml on the wiki.....http://evoecu.logic.net/wiki/File:94170715-v7.zip
**You will see that the user level is higher on some tables. These will show up as blue tables. I did that as an easy way to determine what tables are incorrect. The blue tables are incorrect. I say again the blue tables are incorrect. Any editing or changing of the values in these blue tables could have adverse affects.**
If anyone has any additional findings please send them to me so that I can keep the file up to date.
Old Feb 5, 2010 | 07:46 AM
  #87
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Boosted has asked me already it is on my agenda for this week.
Old Feb 5, 2010 | 07:55 AM
  #88
binky's Avatar
Appauldd-
Thanks for all of your hard work on this new ROM
It is much appreciated!
-Bink
  #89
Appauldd's Avatar
Thanks acamus.
The ISCV demand tables are really not necessary, in my opinion, because this rom, from my testing, does not exhibit throttle hang issues. Those warmup tables are most likely set up wrong but something should be in the rom that is similar.
Go to the wiki link I posted above for the latest version. I also updated the MUT table to allow 2byte logging via EvoScan.
Old Feb 5, 2010 | 08:59 AM
  #90
rdtech's Avatar
Been waiting for this. I'll have to try it out. The so called universal evo8 v7 rom didnt run well at all.
04 evo here.
