Going back to 94170015
I just upgraded, downgraded, ah, whatever, from 9653v7 to 9417v7. I wanted to do this with the fewest changes to the default settings as possible. So, I changed:
Injectors: Latencies/Scaling
Maps: Fuel/Timing
Immobilizer
Seemed to run just fine, but I wanted to improved cold start and cold idle on E85 so I also changed:
ISCV A/C off-N
Idle-N
Injector Cranking Enrichment IPW Adder
After driving 24 hours and all is well, I opened it up this morning and promptly hit fuel cut, so I changed:
Fuel Cut Load
Are there any other settings that might need attention?
Jury is still out here. When I went to the 9653v7 I thought the initial throttle response was a wee bit better. I'm not feeling that in the 9417v7. Anybody else?
I think I'll just drive the new ROM for a couple weeks...and let it sink in.
Maps: Fuel/Timing
Immobilizer
ISCV A/C off-N
Idle-N
Fuel Cut Load
Updated OP with new information.
New findings....(Thanks Acamus)
Warmup table needs verification of function
ISCV Demand table verified addresses as accurate
Code:
<table name="Warmup Enrichment vs RPM" category="Warmup Settings" address="36fe" type="2D" level="2" scaling="Percent (128)"> <table name="RPM" address="64d6" type="X Axis" elements="14" scaling="RPM"/> </table>
Code:
<table name="ISCV Demand Below 500 RPM Idle Recovery Adder (sub_1A51A)" category="ISCV Control" address="1916" type="1D" level="2" scaling="ISCV_AX2_16"/> <table name="ISCV Demand Startup CTS Adder (sub_1AE40)" category="ISCV Control" address="42ae" type="2D" level="2" scaling="ISCV_AX2_8"> <table name="Coolant Temp" address="67a2" type="Y Axis" elements="8" scaling="Temp"/> </table> <table name="ISCV Demand General CTS Subtractor (sub_1AE6E)" category="ISCV Control" address="4372" type="2D" level="2" scaling="ISCV_AX2_8"> <table name="Coolant Temp" address="67a2" type="Y Axis" elements="8" scaling="Temp"/> </table> <table name="ISCV Demand Baro Adder (FFFF8C9A) (sub_1A61C)" category="ISCV Control" address="4339" type="2D" level="2" scaling="ISCV_AX2_8"> <table name="Baro" address="6608" type="Y Axis" elements="5" scaling="Baro16"/> </table> <table name="ISCV Demand RPM Adder* (sub_1B1DA)" category="ISCV Control" address="47d6" type="2D" level="2" scaling="ISCV_AX2_8"> <table name="RPM" address="635a" type="Y Axis" elements="10" scaling="RPM"/> </table> <table name="ISCV Demand CTS Adder #1** (sub_1AC3E, sub_1B3CC, sub_1B664)" category="ISCV Control" address="4276" type="2D" level="2" scaling="ISCV_AX2_8"> <table name="Coolant Temp" address="6884" type="Y Axis" elements="8" scaling="Temp"/> </table> <table name="ISCV Demand CTS Adder #1a*** (sub_1B424) " category="ISCV Control" address="5564" type="2D" level="2" scaling="ISCV_AX2_8"> <table name="Coolant Temp" address="6884" type="Y Axis" elements="8" scaling="Temp"/> </table> <table name="ISCV Demand CTS Adder #1b*** (sub_1B424)" category="ISCV Control" address="4292" type="2D" level="2" scaling="ISCV_AX2_8"> <table name="Coolant Temp" address="6884" type="Y Axis" elements="8" scaling="Temp"/> </table>
Yeah Jeff....they can.
As a matter of fact I would be willing to bet you can use the entire XML for base 94170015 just by making a few small changes in your current XML. I will do some testing ad get back with you.
Oh you might want to give 94170715 a try....No adverse affects for me.
Did you get the IACV back yet? I shipped it a while ago.
Paul
Paul
Paul
If you sent it by USPS then they are holding it for pick up. If not, then no I have not received it.
