Break-thru: Reading ACD ECU with EcuFlash
lol for those looking to pay for this upgrade, I compiled all the options available to the US here - https://www.evolutionm.net/forums/ev...t9as-read.html - is it possible to mimic these set ups using ecuflash?
Updated .xml -> 401403_2-23-10.zip
Figured a few more axis out.
Table Main: ??? x Vehicle Speed
Tables A: Throttle Position x Vehicle Speed
Tables B: Table B, X Axis Tables x Vehicle Speed
Tables C: ??? x Vehicle Speed
Table B, X Axis Tables are used to find the X axis for the B Tables.
Calc = X Axis 1 * X Axis 2 * 4
Axis 1 Tables are Wheel Speed Difference (Rear - Front).
Axis 2 Tables are Vehicle Speed.
So simply, the B Tables X-axis is Wheel Speed Difference times Vehicle Speed.
Still working on the Main Table. Tables C does some jump through the rabbit hole trickery I'm not following, maybe someone else can try to figure it out. (Acamus?)
sba if you could make a ACD Mode button, we could find out what Gravel, Snow, Tarmac, corresponds to. (ie .1, .2, .3)
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Sure, can you email what you have?
I was doing 401501 :P, maybe we can exchange disassies.
sba has done acd mode, it is on mut 3
EDIT:
We have been doing some more research in ADC routine yesterday,
As I wanted to get complete ADC polling variables to be known.
There are more - maybe AYC stuff.
But it seems the ecu is protected somehow we have not been
able to use modified MUT to retrieve it as logging stopped
working with ROM modified.
I believe we need Colby to get the flashing working now.
EDIT:
right folks iv done a bit of digging on the net and found something very interesting for you all.it seems there are 6 inputs to the ACD/AYC control
1.steering wheel angle
2.vehicle speed
3.wheel speed
4.longitudinal G
5.lateral G
6.throttle opening
hope this helps
2.vehicle speed
3.wheel speed
4.longitudinal G
5.lateral G
6.throttle opening
hope this helps
MUT 0x22 - ADC_Channel_9
MUT 0x23 - ADC_Channel_1
MUT 0x24 - ADC_Channel_3
MUT 0x25 - ADC_Channel_2
MUT 0x1B - something calculated from ADC_Channel_2
MUT 0x1F - something calculated from ADC_Channel_2
MUT 0x20 - something calculated from ADC_Channel_2
No offense to the 1.3 folks
