Break-thru: Reading ACD ECU with EcuFlash
Old Feb 15, 2010 | 05:38 PM
  #91
merlin.oz's Avatar
Tried logging my AUDM9 today, it connects, but nothing logs properly. (1.3 cable, v2.5).
Tried changing a request id to 14, same result as Sabin, re post #77, outside array.
I initially had all the boxes ticked, but when connection made, the pumps started activating so I quickly switched of.
I have just checked my cable, pin 1 is joined to pin 15. Pin 9 is still in the connector.
I will break it out and try again, later....
edit: removing pin 9 did not help in my case.
Old Feb 16, 2010 | 10:12 PM
  #92
_Speedy_'s Avatar
Yeah I messaged the evoscan developers, they are going to do some work on the ACD stuff for you guys tonight.. fix the index bounds error, then add some openport 2.0 support for it, and then remove requestids that are doing mapping to real mut requestIDs inside the app.
Old Feb 17, 2010 | 01:26 AM
  #93
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Now you tell... I have just written the logger.
it is currently tested by sba...
Old Feb 17, 2010 | 01:39 AM
  #94
merlin.oz's Avatar
Also, after I had connected to the AWD ECU via EvoScan, the CEL lit-up.
I have just checked, it threw 33 DTC's, basicly everything for AWD and an idle error for the EFI ECU. Weird.
Old Feb 17, 2010 | 06:10 AM
  #95
MR Turco's Avatar
I can test a USDM 9 if you would like. I have a 2.0 cable ready and waiting. Just let me know.
Old Feb 17, 2010 | 07:32 AM
  #96
acamus's Avatar
Hamish just wrote me that anyone who wants to get Evoscan for ACD logging developer purposes shall log into EvoScan page and submit a ticket. He has a fix ready.
Old Feb 17, 2010 | 09:35 AM
  #97
sba's Avatar
sba
Originally Posted by acamus
Hamish just wrote me that anyone who wants to get Evoscan for ACD logging developer purposes into EVoSCan page and submit a ticket. He has a fix ready.
I WANT IT!!!! I still wait for Hamish response about it.
Old Feb 17, 2010 | 02:46 PM
  #98
Ceddy's Avatar
Anyone using the fixed EvoScan yet? I haven't got a reply...
I could make a custom MUT table with all the ADC inputs in it, so we could figure out whats connected to what. That would help in figuring out what the normal MUT Requests are.
Old Feb 18, 2010 | 04:00 AM
  #99
sba's Avatar
sba
I didn't get it neither Acamus. I have send an email and i put a support ticket also, but no reply what-so-ever.
In the mean time, me and Acamus are still working on our version of MUT logger for ACD based on your MHI. So, until i really see the EvoScan, i don't believe it is ready.
But i can say, this ACD is pretty different in responses compared with the engine ECU.
Work in progress
Old Feb 18, 2010 | 06:45 AM
  #100
sba's Avatar
sba
I have EvoScan. Testing in progres...
Old Feb 18, 2010 | 11:01 AM
  #101
colby's Avatar
Sorry for the late reply. If you have a spare ACD, I would be happy to pay to have you send it to me to look at and figure out what might be going wrong with the flashing. If not, I may try to find one myself...
Colby
Originally Posted by sba
Ok,
This really get interesting... Today i tried to write inside the ACD a modification and ... the ECU got bricked (the error log attached)
Now i can just read the ECU with no problem, but i cannot write it anymore or even to log it. The curious thing is that the difference between the original file and what it is now inside the ECU is very small, a few bytes changed. I also attached the file that it should be inside the ECU and the file that it is now.
So:
- ACD_ECU_evo8_org - is the file that was in the ecu from the beginning and i tried to change
- i tried to write something inside. It blocked, gived me the error
- i readed again: read_error
- i tried to write again the first file, same error
- i readed again: read_error2
What is your opinion? Colby?
S.
Old Feb 19, 2010 | 12:49 AM
  #102
merlin.oz's Avatar
colby, email Steve at
steveknightrace@optusnet.com.au
I believe he is willing help out with an AWD ECU.
We would like this issue worked out as it would enable us to flash the evo6.5, VR4 and Legnum, all with 7203 chip.
Old Feb 19, 2010 | 05:19 AM
  #103
sba's Avatar
sba
Colby
Unfortunately i don't have a spare ecu. I'm sorry.
We are waiting for you to find out the problem and resolv it.
But if you don't really find a ACD ECU, i think a Evo 6.5 TME or Eclipse will do also the task.
Old Feb 19, 2010 | 05:21 AM
  #104
sba's Avatar
sba
Is not ready yet for our kind of ecus. But Hamish mailed me that he just got a ACD ECU and it will make it work.
Old Feb 19, 2010 | 05:50 AM
  #105
acamus's Avatar
With the help of sba and merlin.oz we have been able to create a scanner, based on Ceddy's MHI scan. Thank you all for your participation.
Now it seems to be working to the extend of testing purposes. I know sba is currently trying to figure out the input pin request ids.
So we are now waiting to collect the MUT table meaning.
If anyone is eager to help please find logger attached.
The cable needed is OP1.3
File Type: zip
