Break-thru: Reading ACD ECU with EcuFlash
Old Apr 8, 2010 | 08:56 AM
  #241
scheides's Avatar
EvoM Moderator
Do you need the reflash adapter for openport 2.0 to be able to just read the rom? I can't seem to get it to work. I am using the latest ecuflash beta as well.
Old Apr 8, 2010 | 09:59 AM
  #242
evonut270's Avatar
yes the acd still needs flashing voltage to read/write the rom.are you trying to read it on the car or at a bench?
Old Apr 9, 2010 | 07:16 AM
  #243
scheides's Avatar
EvoM Moderator
On the car (05). I'll order up the adapter then, thanks!
Old Apr 9, 2010 | 02:09 PM
  #244
evonut270's Avatar
Not sure if it works on the car
Old Apr 10, 2010 | 01:08 AM
  #245
jdmevo123's Avatar
Has anyone found the evo 8 Ralliart ACD rom yet?
Old Apr 10, 2010 | 09:39 AM
  #246
evonut270's Avatar
there are 3 RA roms for the ACD/AYC.the K1-K2 and C1.the K2 has been read and posted but the K1 and C1 seem to be a bit harder to find
Old Apr 10, 2010 | 05:44 PM
  #247
lan_evo_mr9's Avatar
As far as the tuning for ACD goes, in order to get a more neutral car/better turn in, I'm assuming you would adjust the ACD lockup% tables, yes? I'm looking to tune for autox, so a very sharp turn in and mid corner rotation are of the most importance to me. Would there be any other table to adjust for this setup?
I wish I could get my hands on one of the Gruppe-s flashed ACD units to see what they adjusted and by how much.
Old Apr 11, 2010 | 02:42 AM
  #248
jdmevo123's Avatar
Does anyone know a link to the K2 ralliart rom? Does that work on the Evo 8 JDM 03?
I saw Gruppe S do the reflash now, Is this similar to the Ralliart rom? I am interested because on street the evo definately feels like it could be upgraded in this department. On track what setting do you guys use?
Old Apr 11, 2010 | 08:11 AM
  #249
evonut270's Avatar
the K2 rom is the Gravel/snow rom which im sure will not be much use for Tarmac track work which is why getting the K1 and C1 Tarmac roms would be beneficial.
Old Apr 11, 2010 | 08:13 AM
  #250
evonut270's Avatar
excuse my ignorance but what event is autox? tarmac/gravel?
Old Apr 11, 2010 | 09:00 AM
  #251
Tarmac surfaces, a mix of tight turns, sweepers and don't go above 50-60mph. Its just you vs the clock. The club I run in usually favors the tight/technical courses rather than the faster/open, so it's very beneficial to have a car that can rotate very easily.
Attached Thumbnails Break-thru: Reading ACD ECU with EcuFlash-3705479551_d967a528b8.jpg   Break-thru: Reading ACD ECU with EcuFlash-3899271176_5a02972bbd_o.jpg
Old Apr 12, 2010 | 01:17 AM
  #252
jdmevo123's Avatar
Ok im confused, where is everyone finding all these roms to flash to there car? Is there a central database somewhere?
Old Apr 12, 2010 | 02:12 AM
  #253
evonut270's Avatar
ah i see its more or less what we call "sprinting" over here.autocross here is usually on dirt/grass tracks.once more "testing" has been done on how best to set the diffs im sure more will be posted.i have a few tests being carried out so should have feedback shortly
Old Apr 12, 2010 | 04:22 PM
  #254
Excellent news .
Old Apr 12, 2010 | 06:02 PM
  #255
kruthles's Avatar
Does anybody know if the roms from the following ACD units have been read and made available? I am under the impression that these maps would work on USDM vehicles as they are non AYC.
