Break-thru: Reading ACD ECU with EcuFlash
Old Mar 27, 2010 | 06:17 AM
  #196
Danieln's Avatar
solve it....
thanks
Old Mar 27, 2010 | 08:56 AM
  #197
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Originally Posted by colby
The new version which supports the ACD / H8539FA correctly is here.
Well done.
Off topic:
I will take a chance that we have you on line.
Colby would you be interested in supporting 384kB m32r ECU's (MH8302F/MH8202F)?
Colts, Outlanders, Eclipses, Pajeros/Monteros use them.
I know David Buschur would not mind sending one of his spares to you.
If you need the ROMs shoot me a PM.
Old Mar 27, 2010 | 09:23 AM
  #198
colby's Avatar
that's normal - it uses a different driver and DLL. stick with the beta until i have an official release - no reason not to.
Originally Posted by Danieln
Ecuflash 1422595 don`t work anymore after I try to install the beta ecuflash.
You know why??
I have Tactrix 2.0
Seems that the driver is corrupt or something for 2.0
Old Mar 27, 2010 | 09:25 AM
  #199
colby's Avatar
you should be able to flash the whole ROM - can you be more specific about what the problem is (i.e. post a log...).
Originally Posted by evonut270
I will do and thanks again. The only thing that does not work is flashing full roms over
Old Mar 27, 2010 | 09:26 AM
  #200
colby's Avatar
I should be able to do that fairly easily. I may have one of these ECUs already. Let me check, otherwise I will get in touch with David.
Colby
Originally Posted by acamus
Well done.
Off topic:
Old Mar 27, 2010 | 10:45 AM
  #201
Danieln's Avatar
thanks colby
i will stay with beta than
I was thinking that there are different drivers between versions
Old Mar 27, 2010 | 12:47 PM
  #202
evonut270's Avatar
It's fine now colby I just changed the memory model in the XML of the rom I was tying to flash and hey presto.
Old Mar 27, 2010 | 05:32 PM
  #203
lan_evo_mr9's Avatar
So we can now flash/tune the ACD??!! This is awesome! Thank you guys for all the hard work on this project. Will there/should there be a "how to tune an ACD" type thread available so you can see what does what, how to make oversteer, more or less lock up, etc.?
Edit: I'm installing the beta version and the driver install for op1.3 (yes I know 2.0 is needed, which I have) is taking forever....normal, does it matter, can I cancel? Or do I need to shut the **** up and be patient?
Old Mar 27, 2010 | 06:51 PM
  #204
merlin.oz's Avatar
I have been working on a tuning guide for the ACD+AYC ECU for some months now.
Only 44 drafty pages so far, but will grow and firm-up as Ceddy gets the 3D maps better defined.
Old Mar 27, 2010 | 07:18 PM
  #205
Ceddy's Avatar
Could someone take some ACD logs?
Need someone to log a custom MUT location, and press the ACD button, to see which values correspond to Gravel, Snow, Tarmac. That will tidy up the definition a lot.
(I don't own a ACD, so can't do it myself.)
Old Mar 27, 2010 | 08:04 PM
  #206
merlin.oz's Avatar
edit:
previously reported problem solved.
Evo9 ACD+AYC ECU reflashed.
Old Mar 28, 2010 | 07:48 AM
  #207
sba's Avatar
sba
I can do it Monday if i find some time.
Well done boys!
Sabin
Old Mar 28, 2010 | 07:53 AM
  #208
So let me get this straight so I don't F anything up....
Download beta ecuflash...
Copy/Paste xml's to rommetadata
Does the op2.0 just plug in to the dlc connector, or do you have to mod it in some way? I looked at the schema pic and I'm not sure how to go about that...
Also, where are the table def's for the ACD?
Old Mar 29, 2010 | 07:05 AM
  #209
sba's Avatar
sba
I'd be interested to know a little more about all this, if someone can chime in, maybe even Colby.
[17:01:42.921] flashing tool "mitsubootloader" loaded.
[17:01:42.921] flashing tool "shbootmode" loaded.
[17:01:42.921] flashing tool "shaudmode" loaded.
[17:01:42.921] flashing tool "hondacan" loaded.
shbootmode i know about it, for the SH processors from Subaru Ecus.
I'd like to know if misubootloader can be also used simillar to shbootmode?
And what are the other 2?
Old Mar 31, 2010 | 01:13 AM
  #210
merlin.oz's Avatar
Well I have hit a hole in the road here.
There is a checksum in the ACD code. Change any byte and all three mode lights are lit.
Re-flash the stock ROM back and it reverts to normal.
I suspect its going to take some dis-assembly to get around this issue.
