Break-thru: Reading ACD ECU with EcuFlash
Old Mar 31, 2010 | 03:35 AM
  #211
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Is it possible to flash stock ROM with different ID?
let us say 40150001 into 40140003 without the problem mentioned in above?
Old Mar 31, 2010 | 04:11 AM
  #212
merlin.oz's Avatar
^ I have not tried to but I dont see why not.
It would be a bit of a dissapointment if all we could do is flash stock ralliart code without mods.
Old Mar 31, 2010 | 04:24 AM
  #213
sba's Avatar
sba
I couldn't change the file directly with a different one.
Old Mar 31, 2010 | 04:35 AM
  #214
acamus's Avatar
I am asking in order to sort out the problem.
If it is in code or some "processor security setting".
If you can flash any other stock file and it is running,
means there is something in the code. But if you are unable
to run other stock it means there is some processor intrinsic check.
Old Mar 31, 2010 | 10:03 AM
  #215
Ceddy's Avatar
Well I have hit a hole in the road here.
There is a checksum in the ACD code. Change any byte and all three mode lights are lit.
Re-flash the stock ROM back and it reverts to normal.
I suspect its going to take some dis-assembly to get around this issue.
Does it do this with only a change to one of the maps?
Old Mar 31, 2010 | 11:18 AM
  #216
mrfred's Avatar
I think Colby can handle this within ECUFlash. If no reply from him in this thread within a few days, I'll send him an email.
Old Mar 31, 2010 | 12:09 PM
  #217
colby's Avatar
I'm on it... I should have a fix shortly.
Colby
Old Mar 31, 2010 | 01:38 PM
  #218
merlin.oz's Avatar
^ acamus, i see your point and will check
^ ceddy, I changed one byte by one bit in one map and the checksum triggered
^ colby, thank you
Old Mar 31, 2010 | 01:47 PM
  #219
merlin.oz's Avatar
ok, acamus and colby, its in the code, not hardware.
I just flashed a ralliart ROM into a normal Evo7 ACD ecu and it ran ok in my Evo9.
A bit of cross-checking there.
Old Mar 31, 2010 | 02:05 PM
  #220
colby's Avatar
I sent this back via FedEx 2-day yesterday, FYI.
Originally Posted by scheides
My spare ACD ECU is on its way to him.
Old Mar 31, 2010 | 02:47 PM
  #221
iTune's Avatar
Subscribed!
Do i need a 2.0 cable to be able to help with this, or can i use my 1.3 cable?
Old Mar 31, 2010 | 02:48 PM
  #222
iTune's Avatar
Never mind.....i found the info i was asking about. Only 2.0 will work. I've been waiting for reason to upgrade my 1.3 and now i think i've found it.
Old Mar 31, 2010 | 04:32 PM
  #223
merlin.oz's Avatar
A little bit more data:
The ralliart Evo7 code will only run for a short time in an Evo9 before lighting all the mode lamps.
I dont know why, but suspect its the pressure sensor signal going out of spec.
Maybe the FSM will show why.
Old Mar 31, 2010 | 04:44 PM
  #224
Ceddy's Avatar
Had a quick look at the code. Appears the the two lower bytes of the ASCII Name might be used as a CheckSum. DM4014
There is also a check against the ASCII Name, that is hard coded in.
If Colby has the CheckSum under control, I won't investigate further.
Old Mar 31, 2010 | 04:56 PM
  #225
colby's Avatar
yep.
small roms / older procs make it much easier to find this stuff
