Evo 8 MAP sensor in an evo 9
Old Feb 24, 2010 | 04:03 PM
stefano's Avatar
So I've been chasing down some trouble code gremlins on the Evo 9 I just bought and while trying to track down why my car keeps throwing a p0069 and a p0106 code (both map related), I realized that the previous owner replaced the MAP sensor with an Evo 8 map sensor which has a different part number.
I know the following...
Evo 8 MAP sensor, with part No. MD305600 reads inlet manifold diff pressure.
Evo 9 MAP sensor, with part No. MN153281, reads inlet manifold absolute pressure.
My question is when I replace the sensor with the correct one, am I going to need to retune the car since I'm guessing the load values will be slightly different or am I overthinking this?
Hope this makes sense.
Old Apr 13, 2010 | 08:48 PM
PharmEcis's Avatar
MAP sensor is used for EGR check only unless you are using the sensor for logging and ECU controlled boost.
BeastYamin
Mar 17, 2016 10:35 AM
evohq
Feb 21, 2016 06:49 AM
jameswwt
Aug 1, 2015 03:32 AM
McDougal
May 16, 2013 05:24 PM
mrfred
Aug 14, 2009 07:17 PM
