Compressor surge, or BOV flutter? (my evo)
Old Mar 10, 2010 | 12:56 PM
  #46
nonschlont's Avatar
Originally Posted by Appauldd
I KILLED the flutter! !
I got a great deal on an 18PSI WG actuator. Installed it with slight tension on the WG flapper. I also adjusted my APS dual vent BOV at idle to not move at all (previously it would move about 1-2mm at idle).
The car feels amazing. I can push the gas slightly on the highway and it takes off with constant turbine spool. No more chchchchchch.
SOOO....kill the flutter with the right combination of parts.
Congrats Paul! Thats good to hear!
Im starting to think its my wastegate as well... I rolled the windows down, turned off the radio, and it sorta sounds like a metallic "flutter", different from the sound of the intake spoolin... Its quite noticable in higher gears/low load, as well.
which WG did u go w/?
Old Mar 10, 2010 | 03:02 PM
  #47
nonschlont's Avatar
since Im not gonna be happy till my car is running v7, (again) used my girls laptop and uninstalled everything, used the "revo" started all over from a stock v.7 rom, set up new .xmls threw in the rom, and noticed the gears, (once again, reading off) w/ the rpm/speed/gear table I had come up w/ logging rpm_speed_gear_ratio... So for ****s and giggles, I decided to revert the map back to its stock form, from tephra, and what do you know?
Edit: changed the value for gear 6 to 1, since Im a 5 speed...
worked perfectly! IDK WTF is happening, as I had used that gear map on multiple roms (of mine), and worked perfect (@ the time) well, @ this point IDC who/what/where/when/why, but its seems to be working properly. for now...
Funny thing is, (on my laptop) evoscan installed perfectly w/ gear and rpm speed to gear already in the list... Well on her laptop, it did NOT! So logging rpm_speed_gear_ratio is not hapening! From my experience, if its not showing that its using "BOTH" requst ID's, its not gonna log correctly! And if you "manually" set it up, it will only show 1!
Im gonna continue to use her laptop, and see if I can keep a solid rom on the car...
Old Mar 10, 2010 | 03:50 PM
  #48
Appauldd's Avatar
I picked up an FP 18psi actuator.
Shoot me your 8859 stuff...I've been trying to build the xml but finding all the the tables it tough.
Old Mar 10, 2010 | 10:32 PM
  #49
nonschlont's Avatar
u have mail
Old Mar 10, 2010 | 10:33 PM
  #50
Appauldd's Avatar
WOW....a lot going on in those XMLs. Might take me some time to clean them up a bit.
Old Mar 10, 2010 | 10:48 PM
  #51
nonschlont's Avatar
u might need to delete the "modified" out of the name of the tephra .xml. when using it... (I did) Ya theres quite a few maps, and I got a lil lazy making the defs "perfect" looking, but should work flawlessly... LMK.
Old Oct 6, 2010 | 08:10 PM
  #52
ob5's Avatar
ob5
bump from the dead .... I have just installed a 3 port on my 8 and for the love of god no matter what i do to the boost maps i get a flutter during WOT as boost builds the flutter happens but it dosnt effect the boost any cule in what i could do ?
Old Nov 5, 2010 | 05:31 PM
  #53
High_PSI's Avatar
Could be a tuning issue. I just fixed all my boost leaks and ran shorting piping now my ported OEM IX Turbo Surges like a **** at partial throttle in 4-6 gears. If I back off or give it more gas it stops but I am certain it could be just poor tuning as my car was tuned with these leaks now I don't have any.
tsitalon1
61
Feb 28, 2019 02:44 PM
caduprado
Jul 12, 2015 04:15 PM
MajorMarvel
Jul 12, 2015 04:31 AM
wang4u
Apr 17, 2014 05:01 PM
scothu
Apr 13, 2011 09:18 AM
