JDM Map sensor idle problem???
Old Mar 12, 2010 | 03:15 PM
LGshow19's Avatar
Ight, i just installed the JDM map sensor. Boost reads are fine, but im having a problem with my car wanting to die out.
03' Evo 8
Mods- TBE, ETS intake... before i installed the JDM map sensor my car idle fine. The ETS intake is not the coulpret.
Can anyone shed some light. Thanks in advance.
Old Mar 12, 2010 | 06:33 PM
LGshow19's Avatar
Idle problem...
I put the exact same values Mrfred had posted. Timing is set to 6.... no cams.
Old Mar 13, 2010 | 12:51 AM
ohhgyeahfasho's Avatar
Did you forget to change the 'Map Output (Volts)' [left side] values under the "Map Scaling" table? I have accidentally forgotten to adjust this once and my car felt like it wanted to stall out.
Old Mar 13, 2010 | 07:38 AM
LGshow19's Avatar
Im using rom 94170008... theres no "map scaling table" that was suppose to be copy into the xml.
Old Mar 13, 2010 | 10:46 AM
Oh, I wasn't aware of the rom you were using and for some reason I was thinking you had an Evo 9. Why don't you try running the V7 Tephra and use 96530706. I was under the impression that the 96530706 V7 rom works for all Evo 8's. See if it works and fixes the idle problems, the 96530706 is already set up for PSI Based boost control with the JDM Map Sensor.
Old Mar 13, 2010 | 12:12 PM
LGshow19's Avatar
i dont want to make the move to another rom yet until i need to. Im just using the JDM map sensor to log boost. i just want to figure this out and why is it having these issues. If i cant find a soulution to the idle problems and stalls, im just gonna put the 1-bar back in.
Old Mar 13, 2010 | 03:16 PM
Evo_Jay's Avatar
Well even though you dont wanna move to another ROM, you should.
94170008 was the first revision of the 9417 family. You should upgrade to 94170015, as it is the most current ROm of that family.
Also you can PM me and i can help get you JDM map and idle working together.
Old Mar 15, 2010 | 05:51 PM
LGshow19's Avatar
Anyone having this problem? I put all the values in the same way MrFred posted. Im about to switch over to 0015.
foxbat
Dec 16, 2018 07:04 AM
nisils14
Feb 15, 2017 11:26 AM
babaz7
Mar 3, 2016 08:37 AM
89turbosupra
Oct 9, 2015 09:51 AM
broddey
Feb 18, 2008 02:06 PM
