Scan or battery mess with flash?
Old Jun 5, 2010 | 12:33 PM
rawkus's Avatar
Originally Posted by tscompusa
the only thing that will make the car slower after a ecu reset is the fuel trims. take the car on the interstate and let it relearn the fuel trims and you should be back to normal.
If I am not mistaken, and feel free to prove me wrong, but fuel trims only effect closed loop, or cruising fuel trims, not open loop, or wide open fuel trims. If the car feels slower under full throttle, relearning fuel trims won't help anything.
Dan
Old Jun 5, 2010 | 03:36 PM
Werd's Avatar
I haven't heard closed or open loop in years so I really don't remember **** about it lol, so I can't confirm or deny that.
Old Jun 5, 2010 | 05:21 PM
tscompusa2's Avatar
thats correct. once WOT and open loop the trims are pretty much ignored.. doesn't mean you can throw injectors in a car and not set latencies or scaling though.
the transformation from closed to open will slightly effect the wot pull from the beginning though. (Closed Loop) LT Trim Control.
to really effect a tune you have to change the injector scaling or latency, then you will throw off the trims permanently until you rescale and the fuel map will be inaccurate depending how much scaling was changed as well.
on evo X's if you dont mod that trim control you can really damage the motor... not so much on evo 8/9
Old Jun 6, 2010 | 08:04 AM
rawkus's Avatar
I'm with you 100% on setting injector sizing and latencies. That is the first step to a good tune.
Dan
MR Turco
Jul 2, 2025 05:30 PM
overdrive1
Jul 13, 2024 09:45 AM
BrandonIX
Dec 7, 2016 02:34 PM
Evo_Goodness
Aug 4, 2016 05:51 PM
caymandiver75
Sep 20, 2004 03:28 PM
