How are u guys launching with V7 launch map
Old Nov 16, 2010 | 02:42 PM
  #31
Raptord's Avatar
Here's a launch map I've been trying out. It's nothing too extreme since I'm on the stuck clutch anyway so it's useless for me to be launching with boatloads of boost. I've never actually launched the car with these settings, I just got on the 2-step a bit to see how it would work out.
Video:
http://www.facebook.com/video/video.php?v=1503651749533
Logs (ignore rpm, I had accidently changed the adresses in the MUT table. my 2-step is at 5k)
Old Nov 16, 2010 | 05:46 PM
  #32
widge's Avatar
Thats nice, i might try your settings i cant get the car to knock less then 7, but im building like 18psi on the 2 step which i think is a little much,
Im also at -10 timing on 2 step which also could be a tad to much haha
Old Nov 16, 2010 | 06:21 PM
  #33
Raptord's Avatar
Yea, like I said I'm not going too aggressive because I can't really take advantage of the extra power off the line, I'd just melt the clutch even faster
Old Nov 17, 2010 | 02:09 AM
  #34
widge's Avatar
lol sweet ill try it out when i can and post back with results
Old Nov 17, 2010 | 05:13 AM
  #35
Spec-Ops1's Avatar
widge... in the negative is partially your issue, you may also need to set your TPS to 60 or 70%
Old Nov 17, 2010 | 05:15 AM
  #36
Spec-Ops1's Avatar
raptord... the issue isn't building the boost without knock, that part is easy .... its the actual launch process that is the issue because when you give the appropriate fueling for everything to yield no knock and the correct boost level, the car bogs off the line and sounds flooded really.
Old Nov 17, 2010 | 11:17 AM
  #37
ant_turbo's Avatar
Ease into the launch map.. Mines is set to active @40% Tps.. So what I do is ease in at 40%Tps then mash the pedal.. See if that helps,,
Old Nov 17, 2010 | 12:11 PM
  #38
nightwalker's Avatar
This is my launch map.
It builds 10 psi at 5250rpm and doesn't knock or bog. The rest of the map is my normal map. I've found this integrates the best and produces good runs for me.
Old Nov 17, 2010 | 09:41 PM
  #39
widge's Avatar
Some good info here
ive got my TPS 40%, ill try some of the above mentioned settings and see how i go
Cheers guys
Old Nov 18, 2010 | 06:50 AM
  #40
Spec-Ops1's Avatar
Can you place another picture with your actual timing map
Old Nov 18, 2010 | 01:39 PM
  #41
mchristian's Avatar
+1 and can you give us a few details on your setup? Have you tried this map at a 6k launch?
Old Nov 18, 2010 | 10:51 PM
  #42
So here is my ignition map
I let out the clutch pedal until the car starts to move, then I push the pedal back in a bit, while I pretty much almost floor the gas.
I have my launch map tps value set at 50% +. Once I lay into the throttle more, you can hear the car start to pop and boost builds. The way it's set up right now I get about 10 psi out of the hole, and it's enough to spin the tires (stock size). If I launch any higher, it will just spin more. I don't bog at this rpm, and I can cut pretty consistent 1.6-1.7 60 foots with my street tires.
You can lower the timing at your launch rpm to increase how much boost you want. You want to keep it pretty rich, but not to the point where you are flooding the engine. around 10.0 works for me.
Old Nov 19, 2010 | 05:55 AM
  #43
Spec-Ops1's Avatar
Something else to try here i guess...
Thanks for the input.
mr evo7
Oct 30, 2016 03:17 PM
mr evo7
Sep 20, 2015 12:31 PM
kubaolong
Sep 18, 2013 06:48 AM
06Black
Mar 4, 2011 01:37 PM
